My T5.1 California SE is a few months short of 10 yrs old and will be upgraded when the New California is available to order in the UK. Just over 9.5 yrs ago I fitted a 100 w solar panel system from Roger Donahugh of solarcampersolutions.com.
2 weeks ago it failed after 9+ yrs.
So what to do. A new Solar Panel and frame is just over £400 as I didn't need a new MPPT module as my old one, non- Bluetooth and with a plug-in LCD display controller, was working fine. If I had been keeping the van I would have just replaced like for like from Roger, but with about 6 months of ownership to go and wanting to keep the convenience of Solar I decided to look for an alternative.
Renogy had a summer sale on and their flexible 100 w panel seemed to fit the bill. Same output and smaller physical dimensions than my present panel and frame. Also bought the extension leads as the Renogy panel outputs ended in special waterproof plugs.
Removed the old panel and frame and removed its junction box. Cleaned old panel and degreased surface and fixed new panel, as suggested by Renogy, with 2" wide industrial Velco tape. As the new panel also had 6 x 5mm eyelets I also drilled 5mm holes in my old panel and used 4mm nylon ties as an addition.
Reattached the frame and wired up and hey presto back in business.
Even this morning, dull overcast and light drizzle the leisure batteries were soon back to 100% and all for less than £120.
