The engine fan on my 2020 T6.1 California Ocean continues to run very noisily for over 5 minutes after turning off the ignition. This happens on both long and short runs - is this normal ?
The vehicle is fitted with a Particulate filter that slowly fills up with soot and this has to be burnt off otherwise it would get blocked up.I think it is every journey but will double check. What is regeneration? Cheers
I have learnt to feel when it is doing it now and if still doing it when I pull up I keep the engine running on a fast idle until it finishes.
The vehicle is fitted with a Particulate filter that slowly fills up with ash and this has to be burnt off otherwise it would get blocked up.
Try to set your destination a few miles earlier. Maybe your regen will be ready when you are home then?The regen seems to work via the satnav, it always kicks in as I pull onto my drive
Yes I knew that but, I was trying to keep it short and simple.Very close, but it actually fills with soot and then this is burnt off leaving a small amount of ash.
The ash gradually builds up, but once full the filter has to be replaced (dealer) or removed and backwashed by independent specialists
Do you recall what RPM tickover was at the time?I did a seven March journey this morning and when I got to my destination and switched ignition off, I’ve could hear a fan running wasn’t sure if this was a region or not it also smelt quite hot. I checked to make sure there was sufficient coolant and the cooler bottle was full. Can somebody confirm with this that your region? Cause I’ve never actually seen it happen before and how can I confirm it was actually completed?
If you have a carista you can download the DPF MONITORING app. You can see everything you need to know on that. Soot levels. Last time regen was time and distance. And if it’s doing a regen at that moment. I use mine all the time very useful app.I did a seven March journey this morning and when I got to my destination and switched ignition off, I’ve could hear a fan running wasn’t sure if this was a region or not it also smelt quite hot. I checked to make sure there was sufficient coolant and the cooler bottle was full. Can somebody confirm with this that your region? Cause I’ve never actually seen it happen before and how can I confirm it was actually completed?
I do have a Carista does it require my to activate a subscription to check ?If you have a carista you can download the DPF MONITORING app. You can see everything you need to know on that. Soot levels. Last time regen was time and distance. And if it’s doing a regen at that moment. I use mine all the time very useful app.
No. The app uses the carista devices as a Bluetooth connection.I do have a Carista does it require my to activate a subscription to check ?
I will go and check later this morning - I guess you just need to pay the subscription to make a change any idea which menu its under and does the vehicle need to be running ?No. The app uses the carista devices as a Bluetooth connection.
You just need to use the carista as a connecting device you don’t actually need to use the carista app just the dpf app that you will need to download from the Apple Store. You select the engine code in the dpf app that matches your van and that’s about it. Very easy when you get the hang of itI will go and check later this morning - I guess you just need to pay the subscription to make a change any idea which menu its under and does the vehicle need to be running ?
ok which dpf appYou just need to use the carista as a connecting device you don’t actually need to use the carista app just the dpf app that you will need to download from the Apple Store. You select the engine code in the dpf app that matches your van and that’s about it. Very easy when you get the hang of it
