Anyone replaced the under-seat battery with this 150AH KS-Energy Lithium?
If your batteries catch fire, you won’t be insured.
Remember all those buses, phones, EVs and even aeroplanes that caught fire carrying lithium batteries?? You would have to be very confident in what you’re doing putting lithium batteries in your £70,000 van.
@akprincehbd thanks for the details. Still not quite clear to me how you managed to secure those batteries in place. Do you happen to have pics?
@yanathem the strap method is one I considered. This could work to secure a custom battery that replaces the existing one under the driver's seat (left hand drive van), but I couldn't see how to do something similar in the compartment under the fridge. Mind you, with a large enough battery, one is probably enough, but I have to see the space under the fridge wasted
My AGMs are on their last legs, so it's time for me to do the LifePO thing. I know how to put a battery together, but securing it in place is what has me blocked at this point
Yes thanks for the advice. It has to be very confident and professional, I'm a electrical engineer doing home offgrid conversions. Basically you just need to secure everything making sure there is no piercing or anything when emergency braking. The Epoxy fiber board surounding it should be at least 1mm thick.
The EVs that caught on fire is mainly very strong impact with direct hit causing the battery pack to be deformed and then shortened. And mostly they were Li-ions rather than Lifepo4.
@Nand0 ye I can take some pictures later one when I got time.
If you plan to put only 1x 314ah pack (4kwh) I suggest to put it under front seat, it will balance out the weight a bit. 4kwh is already too good enough for most ppl usage
Much appreciated
I agree, 1x314ah would be enough, but quite frankly, given the prices, and that otherwise the space under the fridge would be wasted, I'd be very tempted to put a second one in there "just because"
What kind of "epoxy fiber board" are you using? I was thinking of using Bakelite boards, but open to better suggestions. I don't want to use wood like some people seem to be using.
I suppose this is what forums are for, but it just seems a little more risky than most things.
The number of deaths in the UK with people charging lithium bikes and scooters in the hallway by the front door is quite high. They end up with a dodgy battery and then a fire whilst charging and its so quick with no way to escape. This seems a little like charging a scooter in your bedroom.
You two clearly know what you're doing but I worry all the same.
Having said that I live in a 1960s house with a garage on the ground floor with a very heavy 1960s fire door. In the 1960s they expected cars to catch fire. We have since converted part of that into a utility room where I charge our Dyson. After 2 Dyson batteries died I got a replacement from Amazon or Ebay. So I suppose I should practice what I preach. I'm glad its behind that door though.
Having said that I live in a 1960s house with a garage on the ground floor with a very heavy 1960s fire door. In the 1960s they expected cars to catch fire. We have since converted part of that into a utility room where I charge our Dyson. After 2 Dyson batteries died I got a replacement from Amazon or Ebay. So I suppose I should practice what I preach. I'm glad it’s behind that door though.
Would that be an asbestos fire door being from the 60s?
If it were a Li-ion battery the resulting fire would be explosive and this is the battery chemistry those scooter and bike fires involve.
My concern would be with the BMS in DIY battery solutions. @akprincehbd what solution do you use for bms if adding the EVE cells in your Cali?
The batteries being discussed are LiPO4 - stable rather than the ones in our phones
Puncture fire and charging fire are different:
Puncture file is battery physical being short ( car crash etc. ) You can easilly avoid by adding enough padding (wood/metal panel of your choice) and fully secure the battery to avoid that.
Charging fire is more or less charger issue/ BMS issue related. I use JIKONG 300A bms per 12v 314AH battery pack. I'm just using 8kwh pack to store the energy but I only use a victron 1200w inverter as I dont use very big appliance.
With a good BMS like JIKONG, if you have single cell exceed the max cell value, all charging shut down(which is what most the charging fire caused). Also you have to have active and passive balancing function, my BMS has 3A active balance. But based on the IR value I bought the EVE 314 from (www.fogstar.co.uk) they seems to be very consistant grade A cell, so I'm not expecting the active balance to kick in a lot of the time. That said with good A cell and good BMS you are on pretty solid safe system. Also this is Lifepo4 not Li-ion so much safer, you will be able to see if a cell is going worse everything is on monitor there is no chance of charing it into a fire.
You need to know what you are doing, basically when you make the pack isolate the + and - make sure they are not touching eachother at any occasion, when you full turn left or right or emergency brake, just make sure all wiring is tidy secured with enough isolation, also fuse it. Then after that the only thing can catch fire is short on a single cell
