Camping display dead and roof up California T6.1 Ocean
JPVW
Zaamslag
T6.1 Ocean 150
Hallo I am from Netherlands and I have a problem with my 2020 California, a T6.1, after standing for about one month with the (hydraulic) roof up the, all the 3 batteries were nearly dead. After charging them the display of the camping unit stayed black and I couldn’t operate the roof, willing it to close and drive.
After reset of all the fail codes in the board computer it still doesn’t work. Any ideas what I can do now? Thank you all for reaction.
Have you tried running the engine?
Try pulling out fuses - I think they would be located to the left of your steering wheel (presuming you are LHD) I recall reading that the T6.1 has an upgraded vehicle control unit covered by 4 fuses.
Try pulling out these fuses (25 amp all aligned together) numbered 5-8 to see if that works.
If successful, give it a good run too.
I suspect that one or both of the leisure batteries have been damaged. I’m sure you will find threads about testing the leisure batteries - it’s a fairly common topic.
Update: I let down the roof by losening the bleed screw behind the operating panel of the roof, and after a few days charging with the 220V camping cable both camping batteries are 100% charged, about 13V and state of health 100%. On the advice of California camper centrum Amersfoort The official VW California dealer I have driven about 30 km’s. Maybe the system will reset by driving, but no result: the panel stays black (after one time showing uplighting stripes on the display)
The dealers advice is to make an apointment with their workshop. But maybe we can come to a solution on the forum, as the dealer is about 3 hours from my home. Thank you all in advance for advice
The dealers advice is to make an apointment with their workshop. But maybe we can come to a solution on the forum, as the dealer is about 3 hours from my home. Thank you all in advance for advice. And yes: I took out all the fuses to check and reset, (fuses under the drivers seat)
I will check these, thank you !
Personally, I would be over to Amersfoort (2 hours 16 minute per Google Maps) and count myself lucky to have them so close.
It would be interesting to hear their verdict, too.
Robbox2
8K
Mansfieldman750
Frankyworthy
14K
Lambeth Cali
Lambeth Cali
Robert Coggins
5K
vbk1975
V
Frankyworthy
10K
Frankyworthy
Frankyworthy
