rippers
Quick question are locking bolts/nut supplied with New Calis that have alloys fitted?? Also same question for the little caps on the nuts?
I had locking wheel nuts delivered on my new vehicle 2015 T5.1. They are a pain in the backside. As they get older their thread deteriorates and are very difficult to remove and the key will wobble off and scratch your alloys.
Also if you have a service or have your tyres replaced or repaired and the service centre puts them on tight you will struggle to get them off.
I am removing them entirely and just going with standard bolts.
Criminals can remove a locking wheel nut in seconds anyway.
Yep complete PITA. One of mine has been rounded by over tightening. As soon as the dealership is open for regular business they will be removed and swopped for standard bolts.I had locking wheel nuts delivered on my new vehicle 2015 T5.1. They are a pain in the backside. As they get older their thread deteriorates and are very difficult to remove and the key will wobble off and scratch your alloys.
Exactly I am off to the nearest tyre place to get the last remaining security bolt removed I can't shift it with standard tools and forget using the lever in the VW toolkit.Yep complete PITA. One of mine has been rounded by over tightening. As soon as the dealership is open for regular business they will be removed and swopped for standard bolts.
See post #1713 on "What have you bought for your Cali today" thread. Sorry can't give link. Set via Ukjuzdeals on Amazon £5.95.Yes, to the locking nuts.
No, to the protective caps
These can be acquired from your friendly dealer if he is in a mind to be generous. Otherwise around £40 for a set of 20, I think.
Like you I find the supplied wheel bolt tool useless for lock nut removal due to the angle which tries to spin the lock nut tool out/off the lock nut head.Exactly I am off to the nearest tyre place to get the last remaining security bolt removed I can't shift it with standard tools and forget using the lever in the VW toolkit.
I use a short breaker bar and wheel nut sucket which gives a 90 degree angle and have no problem removing the lock nuts/bolts.
This type. Use the 17mm on the cars.
Pardon our interruption...
www.ebay.co.uk
