Brandrup iXTEND Folding Mattress for VW ID. Buzz - Approx. 120cm x 202cm x 7cm
Brandrup iXTEND Folding Mattress for VW ID. Buzz – Approx. 120cm x 202cm x 7cm
£512.99 Inc VAT
Check out the full ID. Buzz Brandrup range HERE
Pre-Order
SKU: 4260660320894 Category: Tag:
The Brandrup iXTEND Folding Mattress offers excellent comfort for sleeping.
Extended above the folded seats of the passenger compartment and the VW-Multiflexboard, the iXTEND Folding Mattress is a practical sleeping solution that also folds down to store.
The iXTEND folding bed can be folded and transported on the VW-Multiflexboar,  can be opened and folded to the backrest of the 2-seater bench so that a big storage or lying area is created without gaps. Practical to use the additional space as a storage area for luggage on the rear cushion, but also as an easily accessible baby bed or a big lying area for a dog.
Being folded on the VW-Multiflexboard, the iXTEND folding bed can be unfolded forward easily with a flick of the wrist: the loops attached therefore can be used from the right or the left sliding door.
The flame retardant foam applying to automotive standards can be removed easily, if the VW original fabric cover has to be cleaned, the two cold-cure foam layers can be turned over and the fabric can be washed in a program for wool at 30°C.
Materials:
  • A foam center – a concerted combination of cold-cure foam, which is adjusted to the underground of the vehicle and the bodyweight of a person
  • The lower area is firmer, so that all edges, gaps, joins, and even the safety locks of the bench are covered and not perceptible
  • The upper area is softer so that the foam adapts well to the body and supports it comfortably.
There are also Brandrup Fitted Sheets which can be purchased to protect the mattress:
Single Jersey
Nicki-Plush
100 709 029
Brandrup
Brandrup is High-quality campervan accessories Brand for Volkswagen California, Multivan, Caddy, and Mercedes Marco Polos.
Be the first to review “Brandrup iXTEND Folding Mattress for VW ID. Buzz – Approx. 120cm x 202cm x 7cm”
£512.99 Inc VAT
