Brandrup Single Side Panel for VW California T5 / T6 / T6.1 & Mercedes Marco Polo
The Brandrup single side panel is for the wind-out awning and can be attached to either side to create a shaded area.
It is very easy to fit the wind-out awning, simply slide the top of the side panel over the awning arm pull the zipper together, zip up and it’s ready to be pegged out to your desired angle.
The guying to the ground should be done without tightening too much and at an angle to offer less wind resistance and increase space within the awning.
The side panel can also be rolled up and fixed to the awning arm when stationary.
Fabric: Airtex Top, with anti-slip inserts and hook-and-loop fastener (velcro).
Dimensions: approx. 1.79m width x 2.03m height
Weight: approx. 1.35 kg.
Please Note: This is for just ONE panel ONLY, if you require both sides please select a quantity of ‘two’.
Colour: “Reflex silver/Red Gold”.
Made in Germany.
100 400 058
Reviews (2)
2 reviews for Brandrup Single Side Panel for VW California T5 / T6 / T6.1 & Mercedes Marco Polo
£168.95 Inc VAT
Neil Kirkwood (verified owner) –
Great service and delivery. It’s a very expensive product but it looks like the usual Brandrup quality. Get what you pay for I suspect. I’ve not used the side panel yet as it’s for the summer holiday in Europe but based on the design and quality I expect it will be just what I wanted – a little more shelter with minimal packing or weight. Big plusses are it’s so compact that when it’s not being used it folds up and can be stored in the rear door with the two chairs. When it is being used it simply zips onto the awning arm and pegs out for extra shelter from sun, wind and rain.
Ben Wood (verified owner) –
Excellent quality and functionality. The side awning is compact when not in use and very quick and easy to install. It uses a robust zip around the wind out awning strut and pegs down through eyelets on the hem of the canvas. It comes with the pegs and guy ropes. I used it in conjunction with Thule straps to secure the awning in case of any wind gusts It is expensive however, the quality and design of it justifies it. It sheds water in light rain and offers good protection from wind and some privacy when on a site.
