CampervanBits Generic Awning Rail Washing Line - Ford Custom/Nugget/Citroen Holiday/Marco Polo
CampervanBits Generic Awning Rail Washing Line – Ford Custom/Nugget/Citroen Holiday/Marco Polo
£52.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 5060641653800 Categories: , , , Tag:
Do you struggle to find somewhere to dry your towels after a shower or a beach day, or perhaps hang a couple of t-shirts or shorts that have been washed when on longer adventures?
Effortlessly gliding into the vehicle’s awning rail, our awning rail washing line is the perfect solution.
Within minutes, the washing line can be installed and can start drying your belongings!
The aluminium components are powder-coated in black to withstand the elements, paired with the black washing line cord: this compliments any van.
With one continuous length of line threaded between both pieces of aluminium, the washing line can be pulled tight whilst in the awning rail and has a good space for hanging multiple items.
How is it installed?
Already assembled, you will see the washing line is made from two black aluminium powder-coated pieces, where the line is threaded through and knotted tightly.
Attached to these pieces are two thumbscrews, the metal piece simply slides into your awning rail, the line can then be positioned to suit your needs: tighten the handwheels to ensure the product does not move.
To remove: simply ensure the line is empty, slowly unscrew the handwheels, and slide the line out gently!
Worried that the aluminium might scratch your rail?
There’s no need to worry, we have attached soft velcro to the part that slides against your rail to ensure no marks are left!
PLEASE NOTE: more photos to follow, the main photos are on a VW California, the washing line is exactly the same as the VW California ones, the fittings are just slightly different.
If you have a VW California you will need THIS listing to fit your rail
Why not check out some of the Comfortz Leisure products to fit your van:
CampervanBits
Be the first to review “CampervanBits Generic Awning Rail Washing Line – Ford Custom/Nugget/Citroen Holiday/Marco Polo”
£52.99 Inc VAT
Subtotal: £69.94
View basketCheckout
