Comfortz Citroen Relay / Fiat Ducato / Peugeot Boxer – Thermal Windscreen Cover
Comfortz Citroen Relay / Fiat Ducato / Peugeot Boxer / Renault Master (Motorhome) – Thermal Windscreen Cover
£135.00 Inc VAT
Comfortz Citroen Relay / Fiat Ducato / Peugeot Boxer / Renault Master – Thermal Windscreen Cover
Specifically designed to keep your van warmer in the winter and cooler in the summer. This is achieved by sandwiching a layer of insulation between two layers of UV-reflective polyester – reflecting heat away from the outside in the summer and heat back internally in the winter. This cover is super easy to fit – using two door pockets that hook over the top of the doors and tabs that attach around the wing mirrors. The front screen also detaches from the side panels so you can drop it down in the day if extra light is required.
Please Note: “These are not compatible with the base van – please see our other listing >> here<< for the base van.
The cover also fits into a storage bag roughly half the size of similar products on the market!
  • Great for both summer and winter use,
  • Rip resistant,
  • Easy to fit and remove,
  • Compact and lightweight,
Made in Great Britain with full 12-month warranty
Pictures of the base van are for illustration purposes only – you will receive the motorhome variant of this screen from this listing.
External Colour
Reflective Silver Both Sides, Light Grey, Mid Grey, Black, Royal Blue, Maroon, Yellow, Red, Purple, Forest Green, Orange, Navy
Comfortz Leisure
Comfortz Leisure is a small family run business specialising in custom-made accessories for your VW California, campervan or caravan.
Be the first to review “Comfortz Citroen Relay / Fiat Ducato / Peugeot Boxer / Renault Master (Motorhome) – Thermal Windscreen Cover”
You may also like…
£135.00 Inc VAT
Subtotal: £733.91
View basketCheckout
