Sale!
Deluxe 3-Piece Carpet Full Set for Ford Nugget Campervan - Black
Deluxe 3-Piece Carpet Full Set for Ford Nugget Campervan – Black Auto (>2023)
Original price was: £99.99.Current price is: £89.99. Inc VAT
In stock
Deluxe 3-Piece Carpet Full Set for Ford Nugget Campervan – Black Auto(>2023)
(These DO NOT fit the Nugget Plus or Manual transmission – These will be Coming Soon,)
Fits Manual and Auto Ford Nugget upto 2023 – (please see pictures for correct fitting)
If you own a Ford Nugget Campervan and are in search of a full set of carpets, then look no further!
Made from high-quality carpet, this Deluxe 3-Piece Carpet Full Set is the perfect solution, offering protection to your original flooring whilst also providing a cozy feel.
The quality of the carpet is unmatched, being both soft underfoot to provide comfort and easy to brush down and vacuum.
Finished with black leatherette trims,  these deluxe carpets are set off nicely against the interior of any van and give a more ‘homely’ feel, preventing any sharp edges or loose threads.
The underside of the carpet is made from a one-piece non-slip material to help ensure there is no movement once the carpets are placed.
The walk-through mat has embedded push-fit fittings to securely fasten down in your campervan, preventing movement underfoot and providing safety surrounding the pedals.
Simple to clean and hoover: please allow them to dry if you wet them to prevent damage.
Included:
  • 1 x Walk-through cabin carpet, with push-fittings
  • 1 x Rail Mat (we have tested the bed and it safely moves over the carpet)
  • 1 x Boot / Kitchen carpet (this will include the rubber mat section as mentioned above)
Please Note: Due to the size, we have to fold these carpets to be able to ship them, when fitting it’s possible they may take a few days/weeks of use to settle down completely. Alternatively, laying them flat with something with weight on the corners for a couple of days will straighten them out.
Download Plus, Sign, Green. Royalty-Free Vector Graphic - Pixabay Why not treat your exterior with some sleek protection too? You can purchase one of our made-to-order windscreens HERE
Weight 6.5 kg
Dimensions 116 × 47 × 18 cm
Type
Beach 2 Seater Bench, Beach 3 Seater Bench, SE / Ocean 2 Rails, SE / Ocean 3 Rails
CampervanBits
Be the first to review “Deluxe 3-Piece Carpet Full Set for Ford Nugget Campervan – Black Auto (>2023)”
You may also like…
