Dometic CFX3 100 Compressor Fridge Freezer 12v/240v
£1,095.00 Inc VAT
Out of stock
Email Me When Back in Stock
Due to size please allow 3-7 days for delivery.
Here we have the extremely impressive range-topping portable fridge or freezer from Dometic. Ideal for campervans and motorhomes whether needed as the main fridge or if you want to expand what you can cool or can be used as a freezer!
On-road, off-road, on the water or anywhere you want to enjoy fresh food, cold drinks or even ice cream. Explore how the Dometic CFX3 is as versatile as you and your next adventure.
This larger fridge or freezer is ideal for market traders, pop up street restaurants, or for transporting goods that need to be temperature controlled
- Generous storage capacity of 88 l
- Heavy-duty yet lightweight ExoFrame construction with fender frame protected edges and aluminium alloy handles
- Powerful VMSO3 compressor cooling technology efficiently refrigerates and deep-freezes to –22 °C
- Easy-to-read High-Resolution Colour Display and soft-touch buttons enabling seamless control and monitoring of cool box performance
- CFX3 App allows temperature control via WiFi or Bluetooth and provides performance history
- 3-stage dynamic battery protection system prevents dead car battery or allows deep draw on dual batteries
- Active Gasket Technology provides a superior seal to retain cool air and minimise power consumption
- Mobile App keeps detailed records of the temperature and power consumption history (Android and IOS)
Specifications
- Dimensions – depth 530 mm, height 472 mm, width 962 mm
- Net weight 26.9 kg
- Gross volume (EN62552) 99.00 l
- Storage volume – total (EN 62552) 88.00 l
- Input voltage (AC) 100-240 V
- Input voltage (DC) 12/24 V
- Rated input current (AC) 1.28A at 100V, 0.53A at 240V A
- Rated input current (DC) 10.8 A
- Rated input power (AC) 73W
- Input frequency 50/60 Hz
- Colour Slate / Mist
- USB Port 5V, 2A
- Connectivity Type Bluetooth, WiFi
- Basket Yes
- Threaded inserts in base for mounting M6
- Drain plug Yes
- Anti-condensation coil Yes
- Interior light Yes, LED
- Certificates ECE R10, CB, CE, GS
- Cable length supply cable 2.00 m
Performance
- Refrigerant, type R134a
- GWP 1430
- Refrigerant amount 60 g
- CO2 equivalent 0.086 t
- Average energy consumption at AC (EN62552) 0.30 kWh/24h
- Energy Consumption 12 V DC (Ambient@90 ºF, Internal@39 ºF) 1.56 Ah/h
- Energy class EU (1060/2010/EC) A++
- Climate class (EN62552) N/T
- Insulation Thickness 55.00 mm
- Insulation Type PU (Polyurethane)
9600025337
