Dometic CFX3 25 Portable Compressor Fridge or Freezer 12v 24v 240v
£695.00 Inc VAT
Out of stock
Email Me When Back in Stock
Here we have the extremely impressive range-topping portable fridge from Dometic.
On-road, off-road, on the water or anywhere you want to enjoy fresh food, cold drinks or even ice cream. Explore how the Dometic CFX3 is as versatile as you and your next adventure.
- Total volume of 25 l – fits 40 cans or five 1.5 l bottles
- Heavy-duty yet lightweight ExoFrame construction with fender frame protected edges and aluminium alloy handles
- Powerful VMSO3 compressor cooling technology efficiently refrigerates and deep-freezes to –22 °C
- Easy-to-read High-Resolution Colour Display and soft-touch buttons enabling seamless control and monitoring of cool box performance
- CFX3 App allows temperature control via WiFi or Bluetooth and provides performance history
- 3-stage dynamic battery protection system prevents dead car battery or allows deep draw on dual batteries
- Active Gasket Technology provides a superior seal to retain cool air and minimise power consumption
- Mobile App keeps detailed records of the temperature and power consumption history (Android and IOS)
Specifications
- Dimensions – depth 569 mm, height 420 mm, width 342 mm
- Net weight 12.7 kg
- Gross volume (EN62552) 25.00 l
- Storage volume – total (EN 62552) 25.00 l
- Input voltage (AC) 100-240 V
- Input voltage (DC) 12/24 V
- Rated input current (AC) 0.9A at 100V; 0.38A at 240V A
- Rated input current (DC) 3.2A at 24V, 6.5A at 12V A
- Rated input power (AC) 46 W
- Input frequency 50/60 Hz
- Colour Slate / Mist
- USB Port 5V, 2A
- Connectivity Type Bluetooth, WiFi
- Basket Yes
- Threaded inserts in base for mounting M6
- Drain plug Yes
- Anti-condensation coil Yes
- Interior light Yes, LED
- Certificates ECE R10, CB, CE, GS
- Cable length supply cable 2.00 m
Performance
- Refrigerant, type R134a
- GWP 1430
- Refrigerant amount 32 g
- CO2 equivalent 0.046 t
- Average energy consumption at AC (EN62552) 0.21 kWh/24h
- Energy Consumption 12 V DC (Ambient@90 ºF, Internal@39 ºF) 0.92 Ah/h
- Energy class EU (1060/2010/EC) A++
- Climate class (EN62552) N/T
- Insulation Thickness 55.00 mm
- Insulation Type PU (Polyurethane)
9600028463
Reviews (1)
1 review for Dometic CFX3 25 Portable Compressor Fridge or Freezer 12v 24v 240v
janet.wilcock2468 –
Although expensive, this is a quality product. Easy to use, achieves 5c (fridge temperature) very quickly and if you want to use it as a freezer, it took about 2 hours to chill down to – 18c. The basket section is tall enough to hold several average sized wine bottles and I can fit four small ‘food saver’ boxes on the shelf. The CFX3 25 fits easily on the rear shelf of the California Ocean. All in all, very pleased with this purchase from CampervanBits.
