Sale!
Dometic CFX3 75 DZ Compressor Fridge Freezer 12v/240v
Original price was: £1,019.00.£1,014.00Current price is: £1,014.00. Inc VAT
Out of stock
Email Me When Back in Stock
Here we have the extremely impressive range-topping portable dual-zone fridge / freezer from Dometic.
On-road, off-road, on the water or anywhere you want to enjoy fresh food, cold drinks, or even ice cream. Explore how the Dometic CFX3 is as versatile as you and your next adventure.
This larger Fridge / Freezer is ideal for market traders, pop up street restaurants, or for transporting goods that need to be temperature controlled
- Generous storage capacity of 65 l
- Heavy-duty yet lightweight ExoFrame construction with fender frame protected edges and aluminium alloy handles
- Powerful VMSO3 compressor cooling technology efficiently refrigerates and deep-freezes to –22 °C
- Easy-to-read High-Resolution Colour Display and soft-touch buttons enabling seamless control and monitoring of cool box performance
- CFX3 App allows temperature control via WiFi or Bluetooth and provides performance history
- 3-stage dynamic battery protection system prevents dead car battery or allows deep draw on dual batteries
- Active Gasket Technology provides a superior seal to retain cool air and minimise power consumption
- Dual storage compartments with independent temperature control for simultaneous cooling and freezing
- Mobile App keeps detailed records of the temperature and power consumption history (Android and IOS)
Specifications
- Dimensions – depth 495 mm, height 472 mm, width 982 mm
- Net weight 27.8 kg
- Gross volume (EN62552) 74.00 l
- Storage volume – total (EN 62552) 65.00 l
- Input voltage (AC) 100-240 V
- Input voltage (DC) 12/24 V
- Rated input current (AC) 1.12A at 100V, 0.47A at 240V A
- Rated input current (DC) 9.6 A
- Rated input power (AC) 59 W
- Input frequency 50/60 Hz
- Colour Slate / Mist
- USB Port 5V, 2A
- Connectivity Type Bluetooth, WiFi
- Basket Yes
- Threaded inserts in base for mounting M6
- Drain plug Yes
- Anti-condensation coil Yes
- Interior light Yes, LED
- Certificates ECE R10, CB, CE, GS
- Cable length supply cable 2.00 m
Performance
- Refrigerant, type R134a
- GWP 1430
- Refrigerant amount 59 g
- CO2 equivalent 0.084 t
- Average energy consumption at AC (EN62552) 0.30 kWh/24h
- Energy Consumption 12 V DC (Ambient@90 ºF, Internal@39 ºF) 1.43 Ah/h
- Energy class EU (1060/2010/EC) A++
- Climate class (EN62552) N/T
- Insulation Thickness 55.00 mm
- Insulation Type PU (Polyurethane)
9600025333
| Weight | 33.8 kg |
| Dimensions | 525 × 520 × 930 cm |
