Mestic Compressor Cool Box/Fridge/Freezer MCC-18 Litres (12/240v) - Black/Grey with LCD Display Screen
Mestic Compressor Cool Box/Fridge/Freezer MCC-18L (12/240v) – Black/Grey with LCD Display Screen
£239.99 Inc VAT
Only 1 left in stock
Whether you’re on the road or at your final destination, the Mestic Compressor Cool Box/Fridge/Freezer is the perfect addition to your vehicle to keep your items cool. With the ability to use on a 12v or 240v power source, this coolbox keeps the same efficiency regardless of it’s location.
With a capacity of 18L, this compressor cool box is the ideal space for storing your refrigerated items and produce, suitable for 0.5L Bottles.
Split into 2 compartments inside allows the temperature to be controlled efficiently whilst keeping items separate where needed, and the cooler’s weight of 11.9 kg and recessed handles make it easy to transport from one location to another; from your van to your awning etc
Another feature is lighting on the inside: meaning you can see your items in the dark!
Temperature control between -18 °C and +10 °C: you can use the coolbox as a freezer.
Own a VW California?
This 18L Compressor Cool Box/Fridge/Freeze by Mestic fits perfectly under the parcel shelf at the rear of your van, even with the bed on the lowest setting (T5/T6 Owners), meaning it can be tucked away safely during transport. The 12V cable is also long enough to be able to plug the box into the port, which you can find next to your bench seat nearest the sliding door.
To make life even easier, when paired with our Ocean Rear Pull-Out Drawer, the coolbox fits neatly onto the drawer, which means you can plug the coolbox in and pull the drawer out to access your cool/frozen produce without too much hassle or having to pull the whole box out.
(See photos 9 onwards)
LCD Display Screen/Mestic Smartphone App
With the handy LCD, you set the temperature accurately between -18 °C and +10 °C.
The handy Mestic Smartphone App allows you to switch the cooler on/off, adjust the temperature, and choose the desired temperature unit remotely (heading back to your setup after a long day? Log in and adjust the temperature to make sure your beverages are cool when you get back)
USB Connection
The powerful cooler with compressor even features a USB connection, so you can charge your phone or other devices on the go. Ideal for on the road or whilst camping.
Specifications
  • Dimensions (HxWxD): 28.9 x 61.5 x 33.5cm
  • Material: Aluminium
  • Cooling and freezing from: -18°C to +10°C (AC/DC)
  • Weight: 11.9 Kg
Find a copy of the user instructions HERE
Looking for something slightly larger? We also have the 25L version HERE
Mestic
Be the first to review “Mestic Compressor Cool Box/Fridge/Freezer MCC-18L (12/240v) – Black/Grey with LCD Display Screen”
You may also like…
  • Dometic CFX3 25 Portable Compressor Fridge or Freezer 12v 24v 240v
£239.99 Inc VAT
Subtotal: £933.43
View basketCheckout
