Fiamma F45s 2.6m Roll out Awning VW California – Black
£679.99 Inc VAT
Out of stock
Email Me When Back in Stock
Available in Black, this Fiamma Roll out awning comes with everything you need to fit it to your VW California.
Including the additional rain seal.
Please be aware due to the size, this is delivered straight from our supplier – and will most likely be in a lorry so you will need to have it delivered to a point with good access – Mainland UK Delivery only – please get in touch for delivery quotes on other areas.
Permanently fitted to California, easy to roll out, with the winch handle, versatile and expandable the F45 S awning can be used as standard to shelter you from the elements providing an airy shade for the side of your VW camper. We also supply our Comfortz Awning Room for this model which can be seen – – > here
The tough aluminium casing in Deep Black or Titanium silver is designed to be a permanent – and perfect – fit onto your California.
If you would like this awning fitting to your VW California – Please get in touch
Dimensions
  •  The case measures 263cm wide,
  • The awning canopy measures 247cm across,
  • The awning canopy measures 200cm in length,
  •  The shaded area created is 4.9m
  • The unit weighs approximately 19.5kg
Fitting is available in Chesterfield for an additional £100.
The video below shows how our Awning room side panels are fitted to a similar roll-out awning on the VW California.
Colour
Light Grey, Mid Grey, Black, Royal Blue, Maroon, Yellow, Red, Purple, Forest Green, Orange, Silver
Be the first to review “Fiamma F45s 2.6m Roll out Awning VW California – Black”
£679.99 Inc VAT
Subtotal: £411.91
View basketCheckout
