FireAngel Smoke Alarm SB1-R
£9.99 Inc VAT
Only 2 left in stock
This FireAngel smoke alarm uses an optical smoke sensor which is ideal for detecting slow burning fires. It comes with a replaceable battery which will need replacing once you hear the low battery alert. This alarm cannot be connected to other alarms in your home.
Less prone to false alarming from cooking fumes – the FireAngel SB1-R features high performance optical sensors which are recommended by the British Standard BS 5839-6 for installation in circulation areas such as hallways and landings.
  • Use the large central button to easily test and silence your alarm using a sweeping
    brush from below – no need for a step-ladder!
  • Install on landings and in hallways, bedrooms and living spaces. For fire detection in
    your kitchen, attic or garage install a heat alarm.
  • Optical sensor.
  • 9V Replaceable Battery.
  • 3 Year Warranty.
  • Alarm test and silence.
SB1-R
KI975
Weight 0.5 kg
Dimensions 10 × 13 × 8 cm
Be the first to review “FireAngel Smoke Alarm SB1-R”
£9.99 Inc VAT
