Brandrup FLEXBAG Bench Rucksack For All VW T6.1 California Ocean/Coast With 2-Seater Bench – Palladium
£165.99 Inc VAT
Only 1 left in stock
Found this item cheaper?The FLEXBAG Bench Rucksack offers approx. 266 l storage room if the 2-seater bench of VW California is in its foremost position: a lot of protected storage space for bedding and luggage.
The FLEXBAG Bench Rucksack has a zipper with two sliders as well as a zipper inside for easy access to the storage bag of the Second Skin seat cover.
Being empty, the bench rucksack interfolds itself completely, when the bench is pushed backwards: it adapts itself to each position of the 2-seater bench.
If the luggage does not stick over the bed extension, the bench can be pushed back completely.
The bed is made quickly: take out the bedding, flip back the headrests, unlock the backrest and push it backward.
It is not necessary to remove the bench rucksack!
The fixation above is made by means of straps, which can be easily installed or removed with snap fasteners.
The bench rucksack is available for all VW T6.1 California with rear board or rear grating in the original VW-fabric (textile, washable).
Design: Palladium
Weight | 2.5 kg |
Dimensions | 55 × 50 × 10 cm |
Models | VW T6.1 California Ocean/Coast – 100 501 532, VW T6/T5 California Ocean/Coast/Comfortline – 100 501 528 |
You may also like…
£165.99 Inc VAT
