Lockdown Secure Ford Transit MK8 Manual Pedal Lock (2014 – Present)
£85.95 Inc VAT
Check out the full Lockdown Secure range -> HERE <-
Out of stock
Email Me When Back in Stock
This Pedal Lock is for the new MK8 Ford Transit from 2014 onwards
Encasing the clutch and brake pedals the Lockdownsecure HLS Pedal Lock makes for a highly effective theft deterrent
Constructed from 2.25 mm Laser cut Cr4 sheet steel, CNC folded, seam welded with a high visibility orange powder coated finish.
The pedal lock is a heavy-duty container style with a hardened steel pin and when combined with the inbuilt lockshield on the Pedal box proves difficult to access.
A locking rail on the base prevents the box from being pushed down … immobilizing the vehicle as on some of the later T5 and T6 models the van cannot be started without depressing the clutch.
All external stress points are fully welded and finished leaving no access to open edges.
HLS – Hidden Lock System
Supplied with four keys , window sticker and fitting instructions.
Lockdown Secure
Be the first to review “Lockdown Secure Ford Transit MK8 Manual Pedal Lock (2014 – Present)”
£85.95 Inc VAT
Subtotal: £173.98
View basketCheckout
