Sale!
Lockdown Secure VW Transporter T5/T5.1/T6/T6.1 Automatic/Manual Security Pedal Shield
Original price was: £72.95.£64.95Current price is: £64.95. Inc VAT
Check out the full Lockdown Secure range -> HERE <-
Out of stock
Email Me When Back in Stock
If you own a T5, T5.1, T6, or T6.1 and are looking for a simple-to-use yet hard-to-tamper-with pedal lock, the Lockdown Secure version is the perfect solution!
Encasing the brake and accelerator pedals and constructed from 3.2 mm Laser cut Cr4 sheet steel, the Lockdown Secure Pedal Shield is built to provide peace of mind when parking your van and proves successful in deterring thieves.
CNC folded and seam welded with a high-visibility white powder-coated finish, the pedal shield also has complete welding on all external stress points, which leaves no access to open edges.
The lock is a heavy-duty container style with a hardened steel pin, and when combined with the inbuilt lock on the Pedal Shield proves difficult to access.
A shaped profile covering all pedals prevents the plate from being pushed down: immobilizing the vehicle and ensuring it cannot be started/moved.
The lock is embedded into the shield, meaning when not in use the lock can be stored as one piece without the worry about losing any additional parts.
The Pedal Shield is supplied with four keys, a window sticker, and fitting instructions.
Designed and made in Great Britain (To fit vans supplied to the UK)
Please Note: when installing and uninstalling the shield, it is possible the paint will eventually mark or flake off slightly but this does not hinder the use of the product.
Frequently bought together
