Fuller NCC Verified Powerstation Leisure/Caravan Battery Lowcase 110Ah 12V (6110)
£129.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 14469999 Category:
Product Code: 14469999
The Fuller NCC Verified 100Ah Class B Lowcase Leisure Battery is perfect for the user that require a lower capacity battery to cover basic operation of their habitation equipment for short periods away from an electrical hook-up.
The Fuller NCC Verified 100Ah Class B Lowcase Leisure Battery has been specifically manufactured to meet the demands of the leisure market. The Fuller NCC Verified Leisure Batteries are specially designed with the end user in mind. We understand that what one customer demands of a leisure battery can be very different to the requirements of another. In order to fulfil the needs of our customers we have developed a range of Leisure batteries designed to suit the user. This 100Ah Fuller Battery has been extensively tested by the NCC and been verified with the Class B rating. From the latest in leisure battery technology, the NCC have stated a minimum of 167 life cycles to 50% depth of discharge.
Manufactured with a low water loss design and 100Ah, this Class B battery is perfect for those that require a battery to be mostly used when travelling to sights with electrical hook-up.
The battery’s unique Thick-Grid Technology with Glass Fibre Separators plate construction increases electrical capacity and improves deep cycle capability thus providing greater resistance to vibration and extended service life.
Make sure you never allow to run flat and be sure to charge once a month when not in use. Whether you own a small caravan or a mobile home, the Fuller NCC Verified 100Ah Class B Lowcase Leisure Battery is the right choice for you.
Dimensions 34.6 × 17.3 × 19 cm
Be the first to review “Fuller NCC Verified Powerstation Leisure/Caravan Battery Lowcase 110Ah 12V (6110)”
£129.99 Inc VAT
Subtotal: £79.98
View basketCheckout
