Genuine Gok Gas Regulator for VW California T5, T6, T7 Multivan, Mercedes Marco Polo, Ford Nugget
- Replacement gas regulator for T5 / T6 VW California and Mercedes Marco Polo
- Low pressure regulator with integrated safety device against over-pressure
- Version Type EN61
- 30 mbar 0.8 kg
- Made in Germany
| Weight | 0.95 kg |
| Dimensions | 18 × 13 × 7 cm |
Reviews (5)
5 reviews for Genuine Gok Gas Regulator for VW California T5, T6, T7 and Mercedes Marco Polo, Ford Nugget
You may also like…
£46.99 Inc VAT
![s-l1600[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2025/11/s-l16001-1.png)
paulgourong (verified owner) –
Works perfectly.
Becca White (verified owner) –
Quick delivery thanks
degsaith (verified owner) –
Quick delivery. Fitted to gas bottle with no problems.
Kevin Grahame (verified owner) –
Quick and easy to fit but note the left hand threads. I used gas ptfe tape for the connection to the hose and no gas leaks found. Remember to angle the regulator down so it doesn’t rub the wall of the water tank. Hopefully it’ll last up to 10 years like my last one!
chris wells (verified owner) –
Arrived quickly and very easy to fit. It is recommended that the regulator and pipe are changed at set intervals and as both of mine were 10 years old I changed them both.
