VW California
Caravan
Drive-Away Awnings
Tents
Kampa Signal Bright Headtorch – New Technology
£2.99 Inc VAT
In stock
Found this item cheaper?
Kampa Signal Bright Headtorch – New Technology –
Needing a hands-free solution to working in dark environments, or maybe you’re going out in the dark to fill up your water tank. We’ve all done it, maybe you’ve turned up to your campsite later than you expected and you need to set up in the dark. Using an elastic strap, simply pop on this headtorch and leave both of your hands free. This headtorch emits a wider light to allow for a further field of vision. Having 3 different settings allows you to adapt the headtorch for your use: Full brightness, Dimmed and Flashing.
Being battery powered means you don’t have to worry about your light running out of charge, simply pop new batteries in and you’re good to go. (Batteries not included).
This Kampa headtorch might be reasonably priced compared to some of the head torches available but don’t be fooled. The new COB technology emits a far superior light to traditional LEDS and this head torch really is powerful for the money.
The Kampa Signal Bright Headtorch – New Technology uses COB technology. COB stands for “chip on board” and emits a much brighter and wider light that travels a longer distance.
  • On/off switch
  • White light
  • 3 modes: Full brightness/Dimmed/Flashing
Weight 0.07 kg
Dimensions 15 × 19 × 9 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Kampa Signal Bright Headtorch – New Technology”
£2.99 Inc VAT
