Sale!
Kampa Dometic Action Air Drive Away Awning (VW Version)
Kampa Dometic Action AIR Drive Away Awning (VW Version)
Original price was: £564.00.Current price is: £339.99. Inc VAT
Delivery 5-7 Days
Pre-Order
Kampa Dometic Action AIR Drive Away Awning (VW Version) ideal for small campervans VW T5 T6 T6.1 Bongo Transit Vivaro
If you don’t want to spend time setting up and taking down your drive-away awning, then this awning is for you. The Travel Pod Action AIR is a free-standing awning allowing you to drive-away whilst still reserving your pitch on site for when you return.
The Travel Pod Action AIR has a large living area and an optional two berth inner tent can be fitted. The awning comes complete with a fully waterproof clip-in groundsheet which can be removed on sites that do not allow the use of groundsheets. A large protective canopy covers the front door – ideal for poor weather conditions.
*** Please refer to the main listing image for the 2022 version of this awning. The darker mud-walls have been taken a little higher on the 2022 version to improve practicability and enhance the cleaner / sharper looks of this awning.
  • Inflatable – external inflation points
  • Freestanding drive-away awning
  • Weathershield™ 68D material
  • Flame retardant and UV stabilised
  • A massive 6000mm hydrostatic head
  • Seams hot air taped – for maximum weatherproofing
  • Front canopy
  • Door in rear tunnel
  • Adjustable height rear tunnel to suit a wide range of vehicles
  • Full clip-in groundsheet
  • Large front ‘D’ door
  • Window blinds with easy store pockets
  • Large rear door for access to camper through tunnel
  • Optional two-berth inner tent
  • SabreLink™ Flex Ready
Specs
  • Height: 205 cm
  • Packs Size 68cn x 36cm x 34cm
  • Weight 14.83kg
  • Kampa Dometic Action AIR Drive Away Awning (VW Version)
9120001238
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Kampa Dometic Action AIR Drive Away Awning (VW Version)”
You may also like…
  • Kampa Dometic Gale 12v High Pressure Electric Pump
    Original price was: £57.99.Current price is: £52.99. Inc VAT
  • Kampa Twin Drive Away Awning Kit 6mm/4mm to 6mm – 4 Metre
Subtotal: £565.89
View basketCheckout
