Sale!
Mercedes Marco Polo Rear Pull-Out Boot Drawer
Price range: £26.99 through £429.99 Inc VAT
Please Note: We can only deliver this drawer to Mainland UK, we apologise for any inconvenience. Alternatively, we offer a free fitting service if you wish to collect from our store, simply place your order and drop us a call to book your fitting in!
Choose from Black or Grey, and add a rubber mat too if you like!
Are you struggling to reach those items you store in the rear of your Mercedes Marco Polo, or having to move items around constantly to access your must-needed items? Look no further
Designed to be an easy to use, yet sturdy and durable storage solution; the rear pull-out boot drawer ensures the storage space is fully utilized and convenient
Worried about the noise? There’s no need, when travelling you won’t even know the drawer is in place as it locks in place securely.
Specifications
  • Overall dimensions including thumb latch – 100cm x 78cm x 7.5cm = 13 kgs
  • Drawers internals: 93cm x 63cm.
  • The maximum load is 100kg, although we recommend a maximum of 80kgs
Powder-Coated
Finished with either Grey or Black powder-coating, our boot drawer compliments the interior of any van colour and increases its durability: it blends in nicely!
Heavy-Duty Rails
The drawer is mounted to heavy-duty rails to ensure safety and stability when loading and unloading, when the drawer is fully extended the rails lock to ensure there is no movement; equally, when the drawer is pushed fully back into place, the rails will also lock to ensure no movement when travelling
CNC Machined
As this drawer is CNC Machined, the measurements always remain exact and give the drawer a professional finish. Made from a strong 3mm aluminium
Rail Attachments
Our boot drawer is supplied with fittings which slide straight into the rails on your van, once tightened this means the drawer will remain in place with no movement (Check out the video we made a few years ago of the VW California Ocean/SE version, this drawer fits in practically the same way)
Floor Protection
There’s no need to worry about the drawer leaving marks on the floor of your van, the drawer comes with some soft velcro attached to the underside where the frame sits on the flooring which prevents any scratches or marks from occurring. Top tip – if you’re worried about your belongings scratching or moving about on the drawer, lay some anti-slip matting or carpet down!
Powder Coat Colour
Grey Tray, Black Tray, Rubber Mat for Tray
Be the first to review “Mercedes Marco Polo Rear Pull-Out Boot Drawer”
