OLPRO Hive Breeze Drive Away Awning Air With Sleeping Pod 190cm-250cm
£899.00 Inc VAT
Out of stock
Email Me When Back in Stock
OLPRO Hive Breeze Drive Away Awning Air With Sleeping Pod. The Hive Breeze Drive Away Campervan Inflatable Awning is a six sided awning with plenty of living space and an attached sleeping Pod. This means the bedroom isn’t taking up your valuable living space. The Hive has an impressive five Square windows with closing top vents that give you a three hundred and sixty degree view, and the skylights in the roof fill the Hive’s living area with light.
The tunnel that connects to the campervan has two access doors, so no need to walk through the awning to get to the van. The sleeping pod has a large inner tent that will fit a double air bed or can be removed to enlarge your living space further. This awning does not have a bucket groundsheet.
The awning is made from an above-standard 150D Oxford, fully waterproof material, with a rating of 5000 Hydrostatic Head and it also has fully taped seams. The Reinforced TPU Inflatable Beams, provides extra stability. The front door has the benefit of a fly mesh screen for added privacy and to protect you from those pesky bugs.
Specifications
Will Fit:Â All vehicles between a height of 190cm and 250cm
Colours Available: Blue, Grey & Lime
Height (cm): 240cm (94.48″)
Length (cm):Â 330cm (129.92″)
Width (cm):Â 330cm (129.92″)
Packed Dimensions (cm):Â 82cm x 37cm x 37cm (32.28″ x 14.56″ x 14.56″)
Weight (kg):Â 25kg
Hydrostatic Head:Â 5,000mm H/H
Material:Â 150D Oxford
Inflatable Beams:Â Reinforced TPU Beams
Awning Beading: 6mm
Sewn-in Groundsheet:Â Yes
Pitching Time:Â 20 Minutes
Number of Doors:Â 4 (Including Tunnel Doors)
Number of Windows:Â 4 Main Windows, 6 Skylights
Bedroom Inner:Â 2 Berth & Darkened Material
Standing Room:Â Yes
What’s Included? Manual Pump, Pegs, Guy Ropes, Storm Straps, Tunnel Throw Over Straps, Carry Bag, Repair Kit
Weight | 25 kg |
Dimensions | 82 × 37 × 37 cm |
