Vango AirHub II Hexaway Low Drive Away Awning
£869.00 Inc VAT
Out of stock
Email Me When Back in Stock
The new AirHub Hexway allows you to connect the Hub directly to the side of your campervan. Quick and easy to pitch, the Hexaway becomes a spacious gazebo for relaxing and unwinding or a useful storage area for furniture and toys whilst you go off exploring. The AirHub features Vango’s SkyTrack II® system, allowing lanterns to be hung to light up the awning at night and for storage pockets to be suspended, ensuring a clean and tidy area. This must-have drive away is the ideal piece of kit whether you require shade from the sun or shelter from the rain, at any time.
- Vango AirBeam® – Quick to pitch and creates a strong and rigid structure
- Linked-in Groundsheet – Easy to clean groundsheet that can be attached or detached from the living area
- Sentinel Pro – Designed for dedicated motor homers and caravanners who embark on several trips a year. Sentinel Pro is created by a blend of fibres and double ripstop construction, making it extremely waterproof and durable. Not to mention its new ColourLok™ technology to enhance resistance to UV fading.
- AirSpeed® Valve System and easy access positioning – Designed by Vango to inflate your AirBeam®s with even less effort
- Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
- Single Point Inflation – Quick and easy inflation through one valve
- SkyTrack® System – Attachment system which can be used to attach lighting, tidy cables or even hang additional storage units
- High Visibility Guylines with Tidies – High visibility lower half to prevent tripping hazards and ensure stability in high winds, with touch fasteners tidies to roll up the guylines when not in use
- Adjustable Pegging System – Allows awning to be pitched perfectly on uneven surfaces
- Alternating Diamond Clear and Mesh Windows – Not only maximises light, but also allows air to circulate to increase ventilation
- Skylight windows – Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night
- Zipped privacy curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away.
- Two Doors in Tunnel – For convenient access to the front or back of your vehicle
- Roll Away Connecting Tunnel – Quick and easy when you drive away for the day, simply roll back the tunnel
- Flat Entry Groundsheet – Easily dropped to ground level allowing effortless entering without needing to step over the entrance
- Multiple Attachment Methods – Pre-attached 6mm kador, over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp
- AirAway® Vehicle Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel rock pegs & mallet with carry bag, easy pack carry bag and double action pump with carry bag
- Registered design – Unique to Vango
Data
- Total Weight: 20.35kg
- Canvas Weight: 16kg
- Floor size: 330 x 390cm
- Packed size: 70 x 42 x 40cm
AWPHEXAWAC3YTDR
Weight | 20.25 kg |
Dimensions | 70 × 42 × 40 cm |
You may also like…
Vango Airhub Hex & Hexaway Awning Footprint – GP004
Original price was: £33.99.£24.99Current price is: £24.99. Inc VAT -
Vango AirHub Hexaway PRO Air Low Driveaway Awning – 180-210cm
Original price was: £799.00.£780.00Current price is: £780.00. Inc VAT -
Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
Original price was: £21.99.£19.99Current price is: £19.99. Inc VAT
