Original VW Fresh Water Pump – VW California Ocean / SE / Coast
(2 customer reviews)
£36.99 Inc VAT
Only 2 left in stock
A Genuine VW Part
Not to be confused with the cooling system water pump
7E7963385
Also available: Water Tank Lid Opening Tool
Weight 0.65 kg
Dimensions 16 × 11 × 9 cm
Genuine Volkswagen
Explore Volkswagen Genuine Parts, designed especially for our models to help provide optimal vehicle performance & fuel economy.
Reviews (2)
2 reviews for Original VW Fresh Water Pump – VW California Ocean / SE / Coast
  1. dr.robert (verified owner)
    Pump arrived quickly and was stamped with VW logo. Fitted easily and firmly to the water pipe in the tank. The cable ended in bare wire and I couldn’t find any electrical connector in the packaging, but it was easy enough to wire the existing wiring to the new pump with a little junction box. New pump works perfectly and replaces an old pump which had become rather intermittent in its function.
  2. anthonyabp (verified owner)
    Does what it says and identical to original so an OEM part.
    One very slight issue is that a new grommet for the tank where the power cable enters would have been a benefit in the pack and not very costly.
    It covers the possibility that the original is not serviceable for reuse. Also many seem to omit it when refitting due to difficulty getting cable through from tank and forcing grommet back into position which can damage it.
Add a review
You may also like…
  • VW California Genuine Waste-Water Tank Screw Lid
  • Genuine Replacement Tap for VW T4, T5 & T6 California / Marco Polo
  • Puriclean Fresh Water Tank Cleaner 100g Pack
£36.99 Inc VAT
