Outdoor Revolution O-zone 6.0XTR Safari 6 Berth Inflatable Tent
The Outdoor Revolution Ozone Safari takes this already popular design and takes it to allot further with innovative features. There is plenty of add on that can be purchased separately with this tent to really make this a customizable home from home tent.
The Outdoor Revolution O-zone 6.0XTR Safari 6 Berth Inflatable Tent uses Outdoor Revolution Oxygen airframe beams, these are pre-angled to give a more upright space inside and better headroom throughout. The beams come with the patented relieve valve to stop over inflation really good during pitching and warmer climate weather. They also have a Lifetime Guarantee*
The rear bedrooms are made from a darkened twilight micro polyester, to reduce the amount of night to create a better more comfortable sleeping experience, with no early sunrises. The Bedroom can sleep up to 6 people with dividing curtains to allow a fully versatile design. The end bedroom can also be zipped off if needed, this creates more storage space outside of the bedroom.
The main living area has lots of space for tables chairs and storage space for all the family. Access to the main area can be gained by doors on either side which are mesh-backed to allow lots of airflow but keeping unwanted visitors out. There is a central door to split the living area from the main porch. the porch is a great area for cooking and storage.
The front access door is multifunctional and using the multi zip can be opened in many ways to accommodate its use during changing weather or needs.
Specification
- 480HDE Double Rip Stop Fabric – The Optimum Strength to Weight Ratio of Any Awning Fabric, Featuring a Double Rip-Stop Weave to Prevent Accidental Damage from Worsening.
- 6,000mm² Hydrostatic Head & Fully Taped Seams Throughout – Exceptionally Waterproof; Water Will Simply Bead Onto the Surface and Roll Off.
- Quidruple Tube Oxygen Air Frame System – An Ultra-Sturdy Easy to Erect Multiple Inflation Point Gothic Arched Oxygen Air Frame.
- Dynamic Speed Valves – The Quickest, Simplest & Most Reliable Inflation Valve on the Market.
- Intelligent Frame Relief Valve Protection System – Our Exclusive Pressure Relief Valve to Prevent Overinflation, Expelling Any Excess Air Above 6PSI.
- Lifetime Guarantee – On the Oxygen Air Frame Tube Bladders Against Any Manufacturing Faults.
- Zip-Up Curtains – Leaf Pattern Embossed Zip-Up Blinds to Maximise Privacy on an Evening & Block Out Light on Brighter Days.
- Twilight Six Berth Inner Tent & Zipped Dividers – A Darkened Breathable Clip-In Micro-Polyester Inner Tent, Which is Designed to Comfortably Sleep Up to Six Average Adults and Divisible Into Three Separate Two Berth Bedrooms, Using the Zipped Dividers.
- Tinted Anti-Glare Windows – Expansive Windows Granting a Panoramic Vista of the Outside World, Whilst Reducing Glare & Increasing Privacy.
- Sewn-In PE Groundsheet – To Increase Convenience When Pitching, Reduce Water Ingression to the Interior & Prevent Bugs From Accessing Your Living Area.
- Phoenix Mesh Ventilation Fly Screen Panel – Zip-Back Assisted Healing ‘Smart’ Mesh Panel, Which Self-Repair Any Snag Damage Caused by Consistent Usage, Optimise Air Circulation & Keep Insects at Bay. Found on Each Side Access Door, Front Porch Left Hand Upper Window & Front Partition Door.
- Internal PVC Storm Cover – Situated in the Front LH Upper Window For Further Protection Against the Elements When Cooking in Adverse Weather Conditions.
- NEW Double Width Side Eyebrow Canopy – Right Hand Side Pole & Sleeve Porch Area with Total Shelter From the Elements; Perfect for Tying Shoelaces.
- NEW Double Width Side Access Doors – Double Width Veranda Style Side Door Panels for Ease of Access to the Central Living Space.
- NEW Large Central Skylight Window – Enormous Central Roof Light Window to Illuminate the Internal Space & Maintain an Airy Internal Morning Atmosphere.
- NEW Internal Partition Door – Zip-Back Multi-Position Porch Partition Door, Featuring a Phoenix Mesh Panel, Several Large Windows & Privacy Curtains.
- NEW Zip-Back Front Door Panel – Zip-Back Multi-Position Front Door Panel to Enclose the Front Porch Area, Featuring Three Expansive Tinted Windows.
- Zip-Off End Bedroom – The Two Berth End Bedroom Can Be Zipped Fully Off to Create Extra Living/Storage Space.
- Multiple Cable Access Points – Electrical Hook Up Points Extending to the Bedroom for Conveniently Powering Electrical Appliances Inside the Family Tent.
- Vortex Bedroom Ventilation System – A Wealth of Mesh Ventilation Points to Maintain A Pleasant Internal Temperature & Through Flow of Air.
- Extra-Deep Bedrooms – Ergonomically Designed Full Standing Height 240cm Deep Bedrooms to Accommodate Larger Air Beds.
- Lumi-Link & Up/Downlighter Compatible – Giving You the Option of Illuminating Your Family Tent on Those Darker Nights.
- Compatible with our BRAND NEW Optional Utility Extensions: O-zone 6.0XTR Safari Front Air Canopy & O-zone 6.0XTR Safari Side Veranda Canopy.
- Reflective Guylines & Adjusters – High Visibility Guylines to Reduce the Risk of Tripping.
- Packed With: Dual Action Hand Pump, Steel Ground Pegs, Endurance Storm Straps, Repair Kit & Wheeled Holdall.
- Weight: 54.8kg
- Packed Size 98x69x58cm
ORBK8890
Weight | 29.67 kg |
Dimensions | 82 × 53 × 48 cm |
