Portland Water Cap – Inlet (For Motorhomes & Caravans)
£6.99 Inc VAT
Only 1 left in stock
The water inlet cap is a more hygienic way to refill your fresh water tanks. Simply connect your hose to the standard hose connector with its quick release connector and easily refill the fresh water tanks without the need of holding the hose in place. The cap has a handy built in over pressure valve so can also be used on tanks without over pressure valves and will reduce any leaks whilst refilling.
Fits smaller water inlets Cap diameter 6.6cm.
ES2290
Be the first to review “Portland Water Cap – Inlet (For Motorhomes & Caravans)”
£6.99 Inc VAT
