Quest Guardsman Low Wattage Light Up Kettle – 1L
£21.99 Inc VAT
In stock
This is a great low-wattage kettle that lights up when in use.
The glass sides of this kettle allow you to see the water boiling in front of you, with the added blue light it gives a great effect when in use.
The kettle is low wattage giving you peace of mind when using it on a campsite or anywhere where there is limited electricity, drawing less electricity than a standard kettle means that not only will it not have an issue on campsites it is also cheaper to run than the higher wattage rivals which is important as some campsites only allow low wattage items.
The kettle is lightweight with a capacity of 1L gives more than enough capacity for more than 3 mugs of coffee or tea, whilst keeping the size down making it easier to store away also quicker to boil.
K0057
Quest
Quest Leisure Caravan, Camping & Garden Centre supplier of all your accessories needs.
Be the first to review “Quest Guardsman Low Wattage Light Up Kettle – 1L”
£21.99 Inc VAT
