Quest Braunton Low Wattage Collapsible Kettle – 0.8L
This is the excellent Quest collapsible electric kettle.
This kettle can be collapsed when not in use, so it is ideal when space is at a premium.
Not only does the kettle collapse down when not in use, but the handle also folds down, making the packed size even smaller.
The kettle itself is low wattage, allowing it to be used on sites without the danger of tripping the electricity.
The fact that it collapses when not in use makes it extremely easy to store away.
The power indicator lets you know when the kettle is on, and the automatic cut-out switches off when the water is boiled.
3-Pin Plug
K0026
Frequently bought together
- Quest Rocket Low Wattage Stainless Steel Kettle – Cream (1.7L)Add to basket
- Quest Rocket Low Wattage Stainless Steel Kettle – Cream (1L)Add to basket
- Quest Rocket Stainless Steel Low Wattage 2-Slice Toaster – CreamAdd to basket
- Quest Rocket Stainless Steel Low Wattage 2-Slice Toaster – SlateAdd to basket
