Replacement VW California Central Control Panel Knob (Black)
(2 customer reviews)
£10.00 Inc VAT
In stock
In the colour BLACK, as pictured.
Due to a design fault in the original VW Control Panel, it is common for the knob itself to begin to fail to engage when using the menu section. This replacement knob is not an original VW Part but should cure the problem and allow you to use the Control Panel as normal.
Below are some instructions which are available as a download.   Although the instructions are for the genuine VW replacement knob, the fitting is the same for this replacement.
Download Instructions below or watch a quick youtube video:
Download fitting instructions
Unsure or unable to fit the replacement knob?
Have this fitted in our store – M1 Junc 29a – More Details here – – >https://vwcaliforniaclub.com/shop/product/fitting-service
Weight 0.2 kg
CampervanBits
Reviews (2)
2 reviews for Replacement VW California Central Control Panel Knob (Black)
  1. James Glover (verified owner)
    Fairly simple to fit as a replacement for the frequently failing OEM knob. Although it is black, as the display panel is dark (when inactive) it looks fine. When you follow any instructions on removing the control panel and broken knob, don’t bother to remove the electronic ribbon connectors inside the panel as the knob can be replaced without doing so and it looks like a faff to do it. Also go easy on the plastic clips holding the panel’s two halves together and have something handy to keep them out of their corresponding slots while you do the others (guitar plectrums are handy for this).
  2. Peter Skelton (verified owner)
    Bought this item as the official VW one was not in stock plus seeing as it was the VW design that was faulty I thought it might not be so bad getting a different design.
    I was wary of taking the control panel off as we had not long had the camper long and it was the first ‘job’ on the van a 9 year old T5 Ocean.
    Having studied all the (very helpful) videos and instructions here and on YouTube I took the plunge.
    In the end it was very smooth. The new knob works a treat and so much better than the old one which had one of the 3 internal spines snapped off (hence very dodgy selection on rotation). The new knob has a sold connector so no spines to break off.
    A few tips. I didn’t need to disconnect the 2 ribbons and this was fine and made the job easier.
    The 3 sockets in the back were stiffer to take out than expected and it is a fiddle with the control panel still connected by the cables.
    Take your time!
    It is a shame it is black and rather stands out but other than that it is great and so reassuring that we are not suddenly going to have no control panel.
Add a review
You may also like…
  • Genuine VW California Replacement Central Control Panel Knob & Fascia Kit
£10.00 Inc VAT
Subtotal: £1,523.64
View basketCheckout
