Sale!
Ridgemonkey Connect Combi and Steamer
Ridgemonkey Connect Combi and Steamer XXL Granite Edition
Original price was: £38.99.Current price is: £32.99. Inc VAT
Out of stock
Email Me When Back in Stock
Why use several different pans when you can use just one? Featuring a deep-sided flat-bottom frying pan, a four-section pan, and a removable steamer tray, the Ridgemonkey Connect Combi and Steamer XXL Granite Edition will help you to create a different offering every day.
Featuring a unique detachable hinge system that transforms one pan into two, the Ridgemonkey Connect Combi and Steamer has dual cool-touch detachable handles for easy storage, and a non-stick coating that is second to none.
Our all-new granite-style coating makes our pans tougher, more durable, and offers improved non-stick properties taking compact cookware to a whole new level.
  • Granite-style coating with improved non-stick properties
  • 1x flat-bottomed frying pan
  • 1x four-section pan
  • 1x removable heat-resistant steamer tray
  • 1x set of removable magnetic, thermoset plastic cool-touch handles with protective pouch
  • Detachable hinge system
  • Lightweight aluminium construction
  • Sleek Gunmetal Grey finish
  • Ridged exterior for even heat transfer
  • Protected registered design
  • Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Approximate dimensions:
300mm (440mm including handles) x 255mm x 70mm
Weight:
1685g (including handles and steamer tray)
835g (four-section pan)
665g (flat-bottomed pan)
Capacity:
1.7 litres (flat-bottomed pan)
1.4 litres (four-section pan, 1x 800ml & 3x 200ml sections)
Steamer Tray
  • One piece BPA-free construction
  • Heat-resistant food grade materials
  • Three partitioned sections
  • Converts the Connect Combi into a food steamer
Type
With Standard Case, With Free Gorilla Case – Worth £19.99
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “Ridgemonkey Connect Combi and Steamer XXL Granite Edition”
You may also like…
  • RidgeMonkey DLX Standard Plate Set – Twin Pack
    Original price was: £12.99.Current price is: £9.99. Inc VAT
