RidgeMonkey Connect Pan & Griddle XXL (New Granite Edition)
The Connect Pan & Griddle XXL Granite Edition features detachable cool-touch handles and a detachable hinge system that transforms one pan into two – a flat-bottomed pan and a separate griddle pan. The Connect Pan & Griddle XXL also comes with a cheese grater and a large Q-Lock Spatula.
The set is ideal for large omelettes, pizzas, pastas, pies, fried breakfasts etc, it is also perfect when cooking for multiple people.
RM781
To go with the RidgeMonkey Connect Pan & Griddle XXL (New Granite Edition)
https://vwcaliforniaclub.com/shop/product/ridgemonkey-classic-toaster-xl
Check out Ridgemonkeys full Granite Range – https://ridgemonkey.co.uk/?s=granite
  • Granite-style coating with improved non-stick properties
  • 1x griddle pan
  • 1x flat-bottomed pan
  • 1x set of removable magnetic, thermoset plastic cool-touch handles with protective pouch
  • 1x cheese grater and large Q-Lock Spatula with protective pouch
  • Detachable hinge system
  • Lightweight aluminium construction
  • Sleek Gunmetal Grey finish
  • Ridged exterior for even heat transfer
  • Fully compatible with RidgeMonkey Connect Sandwich Toaster Granite Edition
  • Protected registered design
  • Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Type
With Standard Case, With Free Gorilla Case – Worth £19.99
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “RidgeMonkey Connect Pan & Griddle XXL (New Granite Edition)”
You may also like…
  • RidgeMonkey DLX Standard Plate Set – Twin Pack
    Original price was: £12.99.Current price is: £9.99. Inc VAT
£45.95 Inc VAT
