Sale!
Ridgemonkey Outdoor Power Shower Full Kit – 10L
Original price was: £64.99.£49.99Current price is: £49.99. Inc VAT
Check out our full Ridgemonkey range –> Here <–
Only 2 left in stock
The RidgeMonkey Outdoor Power Shower provides a powerful 4.5L per minute flow rate, meaning you can get that clean feeling almost anywhere.
Safe to use with both cold and hot water (10-50 °C), the Outdoor Power Shower is an invaluable addition to your outdoor accessories.
The shower head can attach to any flat surface with the provided suction cup and hook, allowing you to hang it over your head or use it to wash cooking equipment, muddy boots, pets, bikes and much more.
The RidgeMonkey Outdoor Power Shower is compatible with any device that provides a constant 12V 2A power supply, for example, a power pack, leisure battery or vehicle.
The shower lid can also be removed and replaced with the conventional water carrier lid and integrated faucet tap, allowing the water carrier to convert back into a standard sealed unit.
Compatible with all 10 & 15-litre versions of the RidgeMonkey Heavy Duty Water Carrier range.
- Instantly converts Heavy Duty Water Carrier into a powerful, portable shower
- Safe to use with hot water up to 50 °C (50℉ to 122℉).
- Suction cup with hook allows you to hang it over your head
- Tilt the shower head to stop the water flow
- Perfect for camping trips, fishing trips, and other outdoor stayovers
- Easy and quick to assemble and operate
- Powered by any device that provides a constant 12V 2A power supply
- Constructed from rugged and durable materials, perfect for outdoor pursuits
- Fully waterproof IP67 electronic housing
- Full Kit comes supplied with a 10L Heavy Duty Water Carrier in black
Specifications
- Operating Voltage: 10-15V DC
- Max Power: 24W
- Max Flow Rate: 4.5L / Minute
- Weight: 1150g
- Hose: 180cm
- 12V Power Cable: 200cm
- 10 Litre Heavy Duty Water Carrier & lid: 32cm x 30cm x 31cm
- Capacity: 10L
- Power Lid: PP
- Hose: PVC
- Pump: ABS
- Heavy Duty Water Carrier: BPA-free HDPE
RM507
![IMG_20150919_123939247[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2015/09/IMG_20150919_1239392471-350x350.jpg)
