Sale!
RidgeMonkey SpeedFlo Heavy Duty Water Carrier - 10L
RidgeMonkey SpeedFlo Heavy Duty Water Carrier – 10L
Original price was: £16.99.Current price is: £11.99. Inc VAT
Check out our full Ridgemonkey range –> Here  <–
In stock
Whether you’re an avid fisherman, or all-season camper, or require a heavy-duty water carrier; Ridgemonkey’s SpeedFlo Heavy Duty Water Carrier is the perfect solution as it is fully watertight, meaning no leaks!
Made from a thick HDPE body, it can withstand harsh conditions, alongside a carry handle perfect for easy lifting and refilling.
The SpeedFlo Heavy-Duty Water Carrier comes supplied with an updated removable tap with a simple-to-use, single-handed mechanism.
The lids are water-tight, with the tap being uniquely vented to ensure a fast and controlled water flow.
The 10L version also allows for the tap to be stored on the underside of the large lid inside the container.
  • Water-tight interchangeable lid
  • Removable tap
  • Vented lid to ensure a fast and controlled water flow
  • Able to operate mechanism with a single hand
  • Thick and robust HDPE construction
  • BPA free
Specifications
  • 32cm x 18cm x 28cm (HxDxW)
RM760
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “RidgeMonkey SpeedFlo Heavy Duty Water Carrier – 10L”
Subtotal: £486.93
View basketCheckout
