Ridgemonkey Connect Sandwich Toaster XL - Induction Edition
Ridgemonkey Connect Sandwich Toaster XL – Induction Edition (NEW)
£39.99 Inc VAT
Check out our full Ridgemonkey range –> Here  <–
Out of stock
Email Me When Back in Stock
The RidgeMonkey Connect Sandwich Toaster XL Induction Edition boasts several innovative features designed for convenience and versatility.
This Induction Edition is compatible with induction hobs and all other heat sources, including gas, electric, and open fires.
Including detachable cool-touch handles and a unique hinge system that allows you to convert one pan into two and a complete utensil set fitting inside the toaster along with the handles, it allows for easy and efficient storage.
Its square shape also optimizes storage space compared to traditional round cookware.
While it’s perfect for making sandwiches, the Connect Sandwich Toaster is incredibly versatile; suitable for pies, slices, naans, wraps, omelettes, cinnamon swirls, and more!
The granite-style coating enhances durability and non-stick performance, elevating compact cookware standards.
The induction sandwich toaster is specifically aimed at the outdoor industry, meaning it has been crafted to be small and compact whilst also being extremely well-made with everything being packed down into a protective pouch to allow for it to be popped into a draw or carried around safely in a backpack.
Features:
  • Granite-style coating with superior non-stick properties
  • Two flat-bottomed, induction-compatible frying pans
  • Heat-resistant utensil set
  • Removable magnetic cool-touch handles
  • Protective pan pouch
  • Detachable hinge system
  • Lightweight aluminum construction
  • Sleek Gunmetal Grey finish
  • Ridged exterior for even heat distribution
  • Usable on all traditional stoves, direct heat sources, and induction hobs
Specifications:
  • Approximate Dimensions: 235mm (350mm with handles) x 205mm x 40mm
  • Weight: 920g (full pan, including handles and utensils) 385g (each singular pan)
OUT004 GRY
Ridgemonkey Connect Sandwich Toaster XL - Induction Edition (NEW)
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “Ridgemonkey Connect Sandwich Toaster XL – Induction Edition (NEW)”
You may also like…
  • Outdoor Revolution Single Sandwich Toaster/Maker
    Original price was: £13.99.Current price is: £10.96. Inc VAT
  • Outdoor Revolution Double Sandwich Toaster
    Original price was: £16.99.Current price is: £9.99. Inc VAT
£39.99 Inc VAT
