Thule Velospace 3 Premium Platform Tilting Towball Bike Carrier – 3-Bike Version
A premium towbar-mounted bike rack, with a practical attachment system, extended wheelbase capacity, and easy, intuitive handling
Versatile, robust and easy to use
- Easy bike loading: one-hand operated bike arms with strap for easy loading and unloading of all types of bikes
Fits compact van: adjustable tilt angle from 50 to 65° to open trunk of compact van with high mounted rear door
- Boot access: easy boot access with or without bikes loaded thanks to smart foot pedal tilt
- Spacious platform: Generous 19cm distance between bikes reduces the risk of bike-to-bike contact
- Increase bike capacity: bring more bikes with the addition of an easy-to-use bike adapter
- Easy towbar fitting: Easy mounting and adjustment of the bike rack before closing the tightening handle, thanks to the towbar coupling’s initial stability
- Ready for heavy and long bikes: accommodates wheelbases up to 1350 mm and bikes up to 30 kg – ideal for e-bikes, mountain bikes, and more
- Carbon frame compatible
- Wheel mounting on adjustable holders
- Pump buckles
- Tilt function (with bikes)
- Fits cars with exterior spare tyre
- Rear lights
- One Key System compatible
- Lockable rack-to-vehicle
Specifications:
- Max number of bikes: 3(4)
- Load capacity: 60 kg
- Max bike weight: 30 kg
- Dimensions: 133 x 73 x 79 cm
- Folded dimensions: 133 x 73 x 25 cm
- Weight: 21.1 kg
- Fits frame dimensions: 20-90 mm
- Max tyre width: 3″ (4.7″ with Thule extra-long wheel straps)
- Max wheelbase: 1350 mm
- Detachable frame holders
- Distance between bikes: 19 cm
- Power connector: 13-pin
- Colour: Black
- Model number: 9033200
Frequently bought together
You may also like…
Please Allow up to 7 days for delivery :)
£799.99 Inc VAT
