Truma Ultraflow Mains Waterline Adaptor Kit 15M Hose & Pressure Reducer
Tired of to-ing and fro-ing with your water container every time you run out of fresh water?
We have the perfect solution in the way of the Truma Waterline.
This 15 metre hose pipe enables you to link your Ultraflow water system directly to a mains water supply.
Perfect for cutting out one of the very physical chores when using your caravan or motorhome, the waterline comes with an inline pressure reducing valve to ensure that your water system does not become damaged by excessive pressure.
15 metre ‘food quality’ hose pipe which comes complete with fittings
and a special pressure reducing adaptor which allows caravanners to
connect their water system directly to a mains water supply without
modification. Compatible with the Ultraflow filter and Ultraflow compact
water systems, simply by being plugged into the Ultraflow housing.
15 metre length
Compatible with both the Ultraflow Filter Housing and Compact Housing
Inline pressure reducing valve to protect the internal plumbing system
| Weight | 2.5 kg |
| Dimensions | 39 × 39 × 29 cm |
![IMG_20150919_123939247[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2015/09/IMG_20150919_1239392471-350x350.jpg)
