High Flow Submersible 12V DC Pump
£52.99 Inc VAT
Only 2 left in stock
Simple, compact and an economical solution
Long life, very quiet with low power consumption
An inexpensive way to update a manual to an electric system
Maximum continuous operation should not exceed 15 minutes
Do not run pump dry as it will cause pump damage
This Whale Submersible Premium Water Pump GP1652 is a submersible water pump designed for your caravan, motorhome, or campervan. The Whale GP1652 is a best selling submersible water pump due to its suitability for use in a shower, as well as the fact that it is compact, quiet, and also suitable for use in pressure switch and microswitch systems. It is recommended to pump water from external containers.
GP1652
Weight 2.5 kg
Dimensions 39 × 39 × 29 cm
whale
Be the first to review “High Flow Submersible 12V DC Pump”
£52.99 Inc VAT
