Kampa Sprint Air Drive Away Awning Low
£329.00 Inc VAT
Delivery 5-7 Days
Pre-Order
Kampa Sprint air drive away awning low
Park up and add shelter beside your campervan in minutes. The Sprint AIR features lightweight Weathershield 68D material, the reliable Kampa AIR Frame and a compact living space made roomier with the generously sized wet weather entrance. This awning is the perfect size for those weekends away and for couples.
Multi-point Inflation
Durable AIR Poles are inflated individually for the simplest set-up and take-down.
Wet Weather Entrance
Provides sheltered access to the awning and prevents rain from running in when you unzip the door.
Dual Keder
Dual Keder
4 mm and 6 mm keder suitable for campervan and motorhome cassette awnings and awning rail.
Specifications
  • Dimensions product depth 1450 mm
  • Dimensions product height 2000 mm
  • Dimensions product width 2800 mm
  • Connection height min 180.00 cm
  • Connection height max 210.00 cm
  • Net weight 12.08 kg
9120001999
Weight 20 kg
Dimensions 78 × 34 × 32 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Kampa Sprint Air Drive Away Awning Low”
You may also like…
  • Kampa Twin Drive Away Awning Kit 6mm/4mm to 6mm – 4 Metre
  • Kampa Dometic Gale 12v High Pressure Electric Pump
    Original price was: £57.99.Current price is: £52.99. Inc VAT
£329.00 Inc VAT
Subtotal: £114.98
View basketCheckout
