A firm favourite with campers and caravanners alike, the Vango Aurora king size is wider and longer than standard double, offering plenty of space to relax. This 3 season sleeping bag has a superior double-layer construction it’s plush 100% cotton flannel lining and polycotton shell radiates luxury. The bag can be separated to become two single sleeping bags to suit your needs. With its sophisticated checked pattern, you are sure to enjoy a night under the stars with the Aurora.
- Grade A Quality Fill – Superior fibre fill which is designed to be durable, warm and lightweight, while retaining its loft and soft touch
- Independently Tested – Gives you reassurance that the temperature ratings are accurate ISO 23537-1:2016
- Hanging Loops – Allows you to easily hang your bag for quick and easy drying
- Integrated Headrest – Provides extra comfort and warmth for your head
- Square Shaped Sleeping Bag – Provides extra space to have greater freedom of movement when sleeping
- Auto-Lock Two-Way Zip – Seals in warmth and provides adjustable ventilation. Auto-lock prevents the bag from opening during the night and can be accessed from inside the bag
- Woven Zip Puller – Allows you to quickly and easily move the zip
- ThermoLock Pro Insulation – Increased durability, extra warmth and retains loft in damp conditions
- Insulated Zip Baffle – Retains heat within the sleeping bag and reduces cold spots
- Angular Wave Stitching – Evenly spaced to hold insulation in place and ensure even distribution throughout
- Double Sized Bag – Can be converted into two single sized bags, giving extra flexibility
- Offset Double Layer Construction – Counteract seams prevent cold spots at the stitching lines
- Zip Guard with Anti-Catch Piping – Helps to prevent the zip from snagging on the lining, allowing easy opening and closing
- King Size Double Bag – Wider and longer than our standard doubles, offering enhanced space and comfort
- Polair® Sumptuous Shell – Soft to touch, comfortable and durable polycotton fabric, providing you with a luxury home from home sleeping experience
- Polair® Sumptuous Lining – 100% cotton fabric which is comfortable, soft to touch, warm and durable
Specifications
- Total Weight: 6.15kg
- Packsize: L50cm x H54cm x W30cm
- Fill Type: 60% single hole siliconised hollow fibre/40% polyester fill
- Chest Width: 170cm
- Max User Height: 200cm
- Zip Side: Twin
- Tog: 10.0
Product Code: SBUAURORA000002
Reviews (1)
1 review for Vango Aurora Kingsize Sleeping Bag – Grey
![insulated-outdoor-blanko-olpro__47390.1728639734[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2025/03/insulated-outdoor-blanko-olpro__47390.17286397341.png)
jan-1242 (verified owner) –
After much deliberation to find bedding solution for our new California. husbands suggestion of trying this sleeping bag did not appeal, but am now a total convert
Soft cotton lining with fully openable zips prevents overheating and lovely padding gives added comfort to mattress.
Full length zips gives option of using as two separate ‘duvets’ for one in pop top and one in cabin.
