Sale!
Vango Faros III Low Poled Drive-Away Awning - 180-210cm - 2025 MODEL
Vango Faros III Low Poled Drive-Away Awning – 180-210cm – 2025 MODEL (Ex indoor Display)
Original price was: £309.99.Current price is: £279.99. Inc VAT
Out of stock
Email Me When Back in Stock
Vango Faros III Low Drive Away Awning – Roof Rail Connection Height: 180cm to 210cm
As new with full warranty but has been on display in our store
The perfect weekend break companion, the Faros drive away awning works as both a campsite hub for relaxing or a handy storage area for muddy boots or bikes. It now features additional multiple ventilation panels allowing you to control your comfort levels.
This lightweight awning with Powerflex poles features Vango’s Sentinel Active 75D quality fabric ensuring a great compact pack size, ideal for short breaks away without taking up valuable storage space.
Designed with practicality in mind, the Faros is packed full of handy features including easy access flat entry doors and king pole door allowing you to transform the front of your awning into a sun canopy for al fresco dining.
Pack up and bring on the adventure with the Vango Faros awning.
  • Sentinel Active 75D – Lightweight, compact and waterproof. 75D fabric with an HH rating of 3,000MM.
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
  • Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
  • TBSII Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBSII to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
  • Fully Wind and Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp kit system. This ensures our awnings are compatible with any vehicle
  • Bracer Pole Included – Secured in between main poles to enhance stability
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
  • Ventilation panels create a comfortable flow of air through the awning to reduce condensation.
  • Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • King Pole Door – Door can be used as a canopy by adding additional king poles through the door eyelets, providing shelter from sun or rain
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Vango PowerFlex Fibreglass Poles – Creates strong, light and reliable structures
  • Sewn-in Groundsheet – Provides a bug and draught free environment. Groundsheet is attached to the flysheet with an external storm skirt to give all-round protection
  • Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free-standing as you explore for the day. Keep a note of your parking position for when you return and re-attach the awning to your vehicle
  • Clear Visibility Guylines – Bright coloured guylines for clear visibility to prevent tripping hazards and ensure stability in high winds.
  • SkyTrack II – A flexible hanging system which allows you to easily attach lighting or storage. The SkyTrack system allows you to customise your awning to suit your needs
  • Key pegging points are highlighted orange. Pitch these points first to create the correct shape of your awning. Thereafter errect your tent.
  • Easy Pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
Specifications
  • Weight: 10.8kg
  • Depth: 275.0cm
  • Height: 205.0cm
  • Width: 290.0cm
  • Pitching Time: 8mins
  • Kador Length: 260cm
  • Kador Height: 180-210 (Low)cm
  • Connection Width: 240cm
  • Pack size: L68.0 x H24.0 x W28.0cm
  • Rail Weight: 5.6kg
AWVFAROPO000001
Weight 10 kg
Dimensions 70 × 30 × 30 cm
Vango
Be the first to review “Vango Faros III Low Poled Drive-Away Awning – 180-210cm – 2025 MODEL (Ex indoor Display)”
You may also like…
