Vango Galli PRO Air Tall Driveaway Awning - 255-295cm
Vango Galli PRO Air Tall Driveaway Awning – 255-295cm
£1,099.00 Inc VAT
Check Out The Full Vango Pro Driveaway Collection –> Here <–
Looking for a large, versatile additional space for your campervan or motorhome when on holiday?
With enough space for two double bedrooms, the Vango Galli opens up an array of opportunities; whether your older children or grandchildren would like to join you, you need extra storage space or you prefer to sleep in a ‘tent’ environment, the Vango Galli is the perfect awning for family breaks.
Developed from the bestselling Galli III Air, the Galli Pro features a much-requested front porch door creating a spacious porch area for additional storage that can be completely zipped back in warmer weather. An additional side door also provides a more open feel in the awning with both windows and mesh panels for all weather.
The inflatable AirBeam® technology means you can pitch this awning in a matter of minutes so you’ve got more time to enjoy your holiday and the Sentinel ECO Pro fabric, made using recycled materials, is perfect for touring with your vehicle. It’s also made even easier with multiple attachment options and the roll-away tunnel allows you to drive away, leaving your awning free-standing.
Please allow 3-5 working days for delivery.
Features:
  • Inflatable AirBeam® Structure – With 10 years experience in AirBeam® technology, Vango is the leader in pole-free pitching and allows your awning to pitch within a matter of minutes.
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught-free environment
  • AirSpeed® Valve System – Designed by Vango to inflate your AirBeam®s with even less effort
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • SuperBeams™ – Larger diameter beams providing additional structure and stability to the awning
  • TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds.
  • Line-Lok guyline runners – lock securely and are simple to release
  • High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
  • Reflective Webbing – Picks up torchlight so the pegging points are easily spotted in low-light conditions
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Zipped Privacy Curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Ventilation System – Vents to increase airflow and significantly reduce condensation
  • Cable Entry Point – Neatly feed electrical cables into your awning allowing you to easily keep your camping appliances powered
  • Adjustable Pegging Points – Allows awning to be pitched perfectly on uneven surfaces
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams, and people with reduced mobility
  • Pre-Attached Front Canopy – Provides shelter from all weathers and is ideal for socializing
  • SkyTrack II® flexible hanging system which allows you to easily attach lighting, storage, or the new Skyliner ceiling curtain
  • Skylight Windows – Windows that run along the roof line of the awning to enhance light during the day and for star gazing at night
  • Fully Wind & Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
Specifications:
  • Weight 32.5kg
  • Depth 465.0cm
  • Height 210.0cm
  • Width 320.0cm
  • Pitching Time 15mins
  • Kador Length 290cm
  • Kador Height 255-295cm
  • Hand Pump Inflate Time 5mins
  • Pack size L90.0 x H38.0 x W41.0cm
  • Rail Weight 27.2kg
AWTGALPRO000001
Vango Galli PRO Air Low Driveaway Awning
Vango
Be the first to review “Vango Galli PRO Air Tall Driveaway Awning – 255-295cm”
£1,099.00 Inc VAT
