Vango Polaris Kingsize 3 Season Sleeping Bag – Neptune
£79.95 Inc VAT
Out of stock
Email Me When Back in Stock
Indulge in luxurious comfort and warmth with the Polaris Kingsize sleeping bag.
Designed for those who crave extra space, this kingsize sleeping bag is both wider and longer than standard doubles, offering unmatched comfort.
Featuring Polair® Lining and ThermoLock Pro Insulation, it delivers superior durability, warmth, and a lightweight feel while maintaining its loft and soft touch.
Perfect for any camping trip, the Vango Polaris Kingsize sleeping bag guarantees a cosy and restful night’s sleep, providing you with the ultimate blend of space, warmth, and comfort.
With a TOG rating of 10, the Vango Polaris Kingsize is sure to keep you warm even in colder temperatures.
A special feature on the Polaris Kingsize is a twin zip, meaning the sleeping bag can be accessed from both sides.
- Grade A Quality Fill – Superior fibre fill which is designed to be durable, warm and lightweight, while retaining its loft and soft touch
- Offset Double Layer Construction – Counteract seams prevent cold spots at the stitching lines
- Polair SuperSoft Shell – A soft-to-touch 210T microfibre shell fabric that is wonderfully cosy, snug and breathable
- Polair Snug Lining – A super soft and cosy brushed Polair polyester fabric that offers a warm handle. Ideal for snuggling into at night (190T)
- ThermoLock Pro Insulation – Increased durability, extra warmth and retains loft in damp conditions
- Kingsize Bag – Wider and longer than our standard doubles, offering enhanced space and comfort
- Shaped Hood – Improves warmth by reducing heat loss from the head. Drawcord allows adjustment of the hood for controllable heat retention
- Insulated Zip Baffle – Retains heat within the sleeping bag and reduces cold spots
- Square Shaped Sleeping Bag – Provides extra space to have greater freedom of movement when sleeping
- Independently Tested – Reassures you that the temperature ratings are accurate ISO 23537-1:2020
- Auto-Lock Two-Way Zip – Seals in warmth and provides adjustable ventilation. Auto-lock prevents the bag from opening during the night and can be accessed from inside the bag
- Zip Guard – Helps prevent the zip from snagging on the lining, allowing easy opening and closing
- Square Shape Carry Bag – Allows for quick and easy packing
- Horizontal Stitching – Evenly spaced to hold insulation in place and ensure even distribution throughout
- Woven Zip Puller – Allows you to quickly and easily move the zip
- Hanging Loops – Allows you to easily hang your bag for quick and easy drying
Specifications
- Weight: 5kg
- Zip Side: Twin
- Suggested Usage: Min -1°C
- Comfort: 2°C
- Suggested Usage: Max 18°C
- Limit: -3°C
- Extreme: -19°C
- Interior Measurements: 223cm x 168cm x 168cm (Length x Chest Width x Foot Width)
- Max User Height 200cm
- Fill Type: 60% Single Hole siliconised hollow fibre/40% polyester fill
- Packed Dimensions: 50cm x 54cm x 30cm (L x H x W)
- Tog: 10.0
Looking for something slightly smaller?
SBVPOLAR0000001
Frequently bought together
