Vango Tailgate Airhub Low Drive Away Awning - Air
Vango Tailgate Airhub Low Drive Away Awning – Air
£549.00 Inc VAT
Out of stock
Email Me When Back in Stock
The Tailgate AirHub is Vango’s first rear attachment awning, ideal for couples or independent travellers with a spirit of adventure. The perfect quick pitch for short stops, the Tailgate AirHub has been designed with active adventurers in mind. An AirBeam® and AirSpeed® valve system ensures this drive away awning is pitched in a matter of minutes and deflated just as fast. Effortless attachment requires only pegging straps at the front of the vehicle and tunnel area, allowing the awning to fit neatly to your vehicle without the need for kador rails. However, should you wish to use them, the traditional attachment options of roof bar attachment tabs, kador and a sleeve for pole and clamp are also included. Two doors in the connecting tunnel make for a convenient storage area, while Vango’s reliable and lightweight Sentinel Active Fabric, ensures a compact pack size, easily stored away when not in use. The Tailgate AirHub does not require the tailgate to be open to support the structure, so you can simply roll away the connecting tunnel should you want to drive off and explore for the day. Be ready for any adventure with the Tailgate AirHub.
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
  • Optional Groundsheet Protector Available – Protects built in groundsheet from rough ground. Prevents awning base getting wet and dirty, allowing easier pitching, packing and storage
  • AirBeam® Pump Included – Double action pump that will rapidly inflate your AirBeam® Awning which comes complete with a pressure dial and handy carry bag
  • Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
  • Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
  • Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
  • Easypack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • AirSpeed® Valve System and Easy Access Positioning – Designed by Vango to inflate your AirBeam®s with even less effort
  • Inflatable AirBeam® Structure – With 10 years’ experience in AirBeam® technology, we are the leaders in pole free pitching. AirBeam® technology ensures your awning is erect within a matter of minutes allowing you more time to enjoy your holiday (Supplied with double action pump)
  • Sentinel Active Fabric – When pack size and weight are the key influencers in choosing your awning, our specifically designed Sentinel Active fabric will surpass your needs. Sentinel Active is strong, whilst being fully waterproof, ensuring great quality and performance coupled with compact pack sizes
  • Experience AirBeam® Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel pegs with carry bag, carry bag with compression straps and a double action pump with carry bag
  • Optional Carpet Available – Give your awning all the comforts of home without compromising your outdoor experience
Specifications
  • Weight: 12.8kg
  • Packsize: L75.0 x H33.0 x W33.0cm
  • Pitching Time: 8 mins
  • Awning Size: Low
  • Kador Adjustable Height: 180-210cm
  • Kador Length: 220cm
  • Weight without Accessories: 6.1kg
AWRTAILAIS0YTDR
Vango
Be the first to review “Vango Tailgate Airhub Low Drive Away Awning – Air”
£549.00 Inc VAT
