Sale!
Vango Tolga Low Air Drive Away Awning, Ideal for Campervans VW T5 T6 T6.1 California, Marco Polo, Transit Nugget, Vivaro, Traffic, Transporter
This is an indoor ex-display model – in new condition apart from some slight damage done to the floor of the awning with a camp chair whilst in store – we have applied tear aid patches to both sides of the floor as per pictures.
No returns on this item, sold as seen.
The Tolga Air awning is quick & easy to erect with a pitching time of only 8 minutes.
The Tolga awning is designed for the new VW, Bongo and Mercedes Marco Polo size campervans and conversions with a height of 180cm-210cm. Using Vango’s AirBeam® Technology Tolga is simple and fast to inflate, combined with Sentinel Sport fabric which is strong durable and waterproof and uses ColourLok technology to reduce the effects of UV. A handy covered entrance allows additional living space outside your awning, whilst the SkyTrack II® System is perfect for hanging lights and adding a SkyLiner to reduce condensation and provide a thermal barrier. This drive away air awning has a great weight to space ratio ensuring you have all the room you need to enjoy your camping trips whilst still being light-weight and compact to combat the limited storage space often found in a campervan. Enjoy every adventure with the Tolga campervan awning, for wherever you go
- Vango AirBeam® – Quick to pitch and creates a strong and rigid structure
- Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
- Low level vents – Helps circulate air within the awning and reduces condensation
- AirSpeed® Valve System and easy access positioning – Designed by Vango to inflate your AirBeam®s with even less effort
- Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
- AirSpeed® Valve – Simple system with easy access positioning to inflate your AirBeams® with even less effort
- Patented Vango TBS®II Tension Band System ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the pole at 3 points, and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
- Bracer beams included – Designed to fit in between the awnings main AirBeams® to enhance stability in high winds
- SkyTrack® System – Attachment system which can be used to attach lighting, tidy cables or even hang additional storage units
- Webbing storm straps – Provides secure guying at the front and rear of the awning
- High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
- Adjustable Pegging System – Allows awning to be pitched perfectly on uneven surfaces
- Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
- Zipped Privacy Curtains – Simple and quick to use, allowing varying levels of opening. Fitted to the flysheet with no gaps that simply rolls down into a pocket
- Diamond Clear windows – Maximise light and visibility
- Zipped privacy curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away.
- Covered Entry – Gives a sheltered entrance into your awning, which prevents rain from dripping into the living area
- Door in connecting panel – Allows convenient access
- Flat Entry Groundsheet – Easily dropped to ground level allowing effortless entering without needing to step over the entrance
- Two Doors in Tunnel – For convenient access to the front or back of your vehicle
- Roll Away Connecting Tunnel – Quick and easy when you drive away for the day, simply roll back the tunnel
- Mesh Front Door – Fitted with internal mesh panel for bug-free ventilation
- Low Level Ventilation – Helps circulate air within the awning and reduces condensation
- Fully taped seams – All flysheet and groundsheet seams are factory taped which provides a watertight seal
- Supplied with Pack of 10 Skyhooks – Simply slide on to the SkyTrack® System to hang storage or lights
- Optional bedroom inner – Optional extra available to purchase separately
- Cable entry point with tidies – Zipped entry point for power cable, with touch fastener tidies
- Multiple Attachment Methods – Pre-attached 6mm kador, over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp
- AirAway® Vehicle Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel rock pegs & mallet with carry bag, easy pack carry bag and double action pump with carry bag
- SkyLiners included – Reduces the effects of condensation and provides a thermal barrier in cold weather
- Lantern Hanging Points – Conveniently positioned to attach your light(s)
- Fire retardant fabrics – Meets European EN5912 safety standard
- Fully wind and rain tested – Weather tested to the European standard EN5912 by certified test centre
Specifications
- Weight: 17.6kg
- Floor size:185cm living space by 320cm Tunnel size : 135cm
- Packsize: L75.0 x H35.0 x W36.0cm
- Kador Adjustable Height: 180-195
- Weight without Accessories: 12.15kg
- Colour : Shadow Grey
AWQTOLGA S32A3G
You may also like…
Vango Drive Away Awning Kit – 6mm to 4mm (3 Metre)
Original price was: £18.99.£15.99Current price is: £15.99. Inc VAT
Vango Tolga Low Air Drive Away Awning – Shadow Grey (Indoor Ex-Display)
Original price was: £499.00.£299.99Current price is: £299.99. Inc VAT
