VW Multivan California Ocean/Coast (T7) LUXURY Deep Pile Grey Carpets – Walkthrough, Passenger or Boot Area
Please Note: This carpet variant is for the VW Multivan California Ocean/Coast and will NOT fit the Beach/Multivan Van
The CampervanBits Logo is a watermark and is not printed on the carpets!
Made from a luxury, deep-pile, super soft plush carpet, similar to the ones you may have in your home, our luxury carpets for the VW Multivan California have been designed with optimum comfort in mind.
Luxury Grey Carpet with a Black Fabric Trim, these carpets have a professional, sleek finish whilst being durable and easy to vacuum/clean
Walkthrough Carpet
The Walkthrough Carpet is perfect for protecting the original flooring in the cab from wear and tear. It also helps to prevent wear of the original carpet under the driver’s pedals whilst providing a sense of home comfort underfoot. The Walkthrough Carpet has push-fittings which align with the fitments in the flooring itself, preventing movement of the carpet during use.
Foldable Passenger Carpet
An iconic design, our foldable passenger carpet is quirky yet extremely practical! Due to the absence of a rubber insert in the rails in this VW Model, dirt and debris can easily build up within your rails and can often be quite difficult to clean. This passenger carpet completely covers the rails to prevent this from happening, whilst also making the passenger area feel sleek and as one, with a super-plush, luxury, home comfort carpet!
Not to worry, this mat does not hinder the ability to move the seats or to fully make the bed due to its ‘folding lines’. The piece comes as one, but can fold into 3 parts. Once folded completely, the bed can be pulled out to its optimum position, and the mats are still able to be used (Please see images for a clearer explanation!), meaning the mat does not need to be removed in order to make the bed!
Due to its 2 separate fold lines, the mat can also be folded over just once to cover the flooring if you choose to travel with your seats further forward due to items packed in the rear. The joins are barely noticeable once the mat is laid completely flat, and give a super soft living area space when you’re in the van.
Made from our LUXURY deep-pile, grey carpet, this luxury foldable passenger area carpet is the ideal gift for your van to protect the flooring whilst also providing an extremely soft, plush underfoot surface.
Easy to install and remove, you can easily vacuum and treat this luxury carpet like your home carpet.
Rear Boot Carpet
The Rear Boot Carpet is a single piece to complement the foldable passenger mat, with the same aim of preventing dirt and debris from falling into the rails. This carpet is easy to install and slides over the top of your rails.
Important Points To Note:
- The Walkthrough Carpet has been designed to meet the edge of the foldable passenger carpet, leaving the vent clear, for a seamless finish when used together, giving ultimate underfoot comfort throughout the van
- The Rear Boot Carpet has been designed to meet the rear edge of the foldable passenger carpet underneath the seats, for a seamless finish
- These can be used conjunctively with each other, our deluxe black carpets and also with our rubber versions! Meaning, for example, if you would like a rubber front mat with a foldable passenger carpet, then you can do just that, and they’ll align perfectly to leave no gaps as they use the same template!
Check out the Rubber Mats HERE
Check out the Deluxe Black Carpets HERE
Frequently bought together
- Brandrup Air-Safe for use with VW California T4/T5/T6/T6.1, Multivan California (T7) & Caddy – Without Electronic Automatic Closing AidAdd to basket
- VW Multivan California Ocean/Coast (T7) Black Deluxe Carpets – Walkthrough, Passenger or Boot Area – Foldable Passenger CarpetPre-Order
- VW Multivan California Ocean/Coast (T7) Rubber Mats – Walkthrough, Passenger or Boot Area – Foldable Passenger MatAdd to basket
- VW Multivan California Ocean/Coast (T7) Step Mats – Plain Grey (2025>)Add to basket
| Area | Walkthrough Carpet, Foldable Passenger Carpet, Rear Boot Carpet |
Price range: £49.99 through £89.99 Inc VAT
