Whale Standard 12v Water Pump
(1 customer review)
£14.99 Inc VAT
Only 2 left in stock
Standard Submersible Electric Pump 10 ltr/min, 2.4 amps .0.6 Bar, 12 V d.c. Simple, compact and an economical solution Long life, very quiet with low power consumption An inexpensive way to update a manual to an electric system Maximum continuous operation should not exceed 15 minutes Do not run pump dry as it will cause pump damage Do not use to pump water that is over 60oc We recommend the pump stands vertically in the tank Before switching on, place the pump in water and shake for a few seconds to release trapped air. This will ensure successful priming and should be repeated after refilling the water tank
GP1002
Weight 2.5 kg
Dimensions 39 × 39 × 29 cm
Reviews (1)
1 review for Whale Standard 12v Water Pump
  1. Simon Wright (verified owner)
    Needed a replacement pump for my caravan. This did the job well. Usual excellent click and collect service.
Add a review
£14.99 Inc VAT
