Whale Watermaster Assembly 12V High Flow
£72.99 Inc VAT
Only 2 left in stock
Simplifies the connection between an outside water container into the caravan Top performance pump Suitable for microswitch or pressurised systems Choice of flow rate to suit either a simple one or two outlet system with two or more outlets including a shower. Incorporates an anti air-locking pump enhancing the performance of the WHALE water system The easily replaceable pump that can be removed and replaced if necessary Easy-fit plug stays secure Watermaster® with 12 V d.c. High Flow pump and plug for WHALE® Socket
EP1612
Weight 2.5 kg
Dimensions 39 × 39 × 29 cm
Be the first to review “Whale Watermaster Assembly 12V High Flow”
You may also like…
  • Puriclean Fresh Water Tank Cleaner 100g Pack
  • Aquaroll Eco 40L Water Carrier / Container - Blue
£72.99 Inc VAT
